problems using a cascaded layer - wms_name parameter
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Mar 21 11:06:11 EST 2005
Hi Nuno,
if you use a WMS layer in Mapserver WMS client, you just use the name (as
present in the WMS capabilities between <Name>...</Name>), not the
nesting, in your case probably:
"wms_name" "l5mosaic.ecw"
Or are you sayig the actual name of the layer on the remote WMS is
"/landmap/mosaics/landsat/l5mosaic.ecw"?
The / syntax is for Mapserver as a WMS server (wms_layer_group),
indicating how it should build up its WMS capabilities with nesting.
See:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=776
Hope this helps.
Best regards,
Bart
> Dear listers,
> I am trying to use a cascaded layer.
> I call it on my map file like this
> "wms_name" "/landmap/mosaics/landsat/l5mosaic.ecw"
> The server produces an error saying that it is unnable of displaying
> that same layer.
> Does anyone know how to deal with this issue? I do believe that the
> problem is the slash usage...
> Regards,
> Nuno
