Mapserver rpm mandrake 10.1
Lluís Garcia i Mestres
lluisgm at GMAIL.COM
Tue Mar 22 03:39:21 EST 2005
Hi, I've achieved to compile php and mapserver by myself but I get two erros:
- I add the following lines to httpd.conf but apache doesn't reconize php.
AddType application/x-httpd-php-cgi .php .php4 .php3 .phtml
Action application/x-httpd-php-cgi /cgi-bin/php
- On the other hand, I builded a map, just with mapserver, with
different layers and the position looks ok. But when I click on the
map using query or zoom function, it seems like mapserver send a point
2-3 cm upper from where i have clicked.
Thanks a lot, I have spend to much time so I hope figure out soon.
Lluís
On Mon, 21 Mar 2005 08:17:35 -0800, Lyndon Tiu <ltiu at alumni.sfu.ca> wrote:
> Lluis G. Mestres wrote:
> >With Mandrake 10.1 I have the mapserver-4.2.rpm include, and it works ok.
> >The problem is that I can't get the php_mapscript.so to include Maplab.
> >Should I compile mapserver by myself? It's possible to use then the php
> >rpm? I'm geeting crazy to build mapserver.
> What error messages are you getting?
> >If anyone has documentation to
> >compile php and mapserver in Mandrake 10.1 will be wonderful.
> ./configure --help
> should tell you what to do.
> You will see something like this:
> --with-php=DIR
> You need to have php devel packaged installed.
> Lyndon Tiu
