Showing Arc/Info annotations details
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Mar 22 05:09:45 EST 2005
can you try:
CONNECTION "C:/Projekti/GIS/Pula/Streets,0"
Also, try testing your MAP file with shp2img before you start using it in
PHP/Mapscript.
Best regards,
Bart
On Tue, 22 Mar 2005 10:58:30 +0100, Gambin Dejan <Dejan.Gambin at PULA.HR>
wrote:
> I would like to give some details of what have I tried without a
> success:
> I have TX6/TX7 annotation files (streets.txt, streets.tat, streets.txx)
> located in "C:/Projekti/GIS/Pula/Streets" folder. Using ogrinfo streets
> I get:
> Had to open data source read-only.
> INFO: Open of `streets'
> using driver `AVCBin' successful.
> 1: streets (Point)
> ogrinfo -summary streets streets gives me:
> Layer name: streets
> Geometry: Point
> Feature Count: 508
> Extent: (5406638.018711, 4966241.156020) - (5411552.448154,
> 4973139.175613)
> Layer SRS WKT:
> (unknown)
> UserId: Integer (0.0)
> Text: String (0.0)
> Height: Real (0.0)
> Level: Integer (0.0)
> My mapfile loooks like:
> LAYER
> NAME "streets"
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "C:/Projekti/GIS/Pula/Streets,streets"
> TYPE POINT
> LABELITEM "Text"
> CLASS
> NAME "all"
> LABEL
> FONT "arial"
> TYPE truetype
> POSITION AUTO
> SIZE 8
> COLOR 255 0 0
> OUTLINECOLOR 55 55 55
> PARTIALS FALSE
> END
> END
> END
> Trying to show the layer I get "Fatal error: Call to a member function
> on a non-object in ... on line ..."
> // the line calls $mapImg->saveWebImage(); and the $mapImg is evaluated
> before using map->draw PHP/Mapscript method.
> What could be wrong?
> Thanks very much
> Dejan Gambin
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
