making efficient map layers
Frank Warmerdam
fwarmerdam at GMAIL.COM
Tue Mar 22 11:29:47 EST 2005
On Tue, 22 Mar 2005 10:52:32 -0500, Jeff Portwine <jdport at veritime.com> wrote:
> Thanks for the information...
> I can write a script I'm sure, but I have never used the ogr2ogr utility and
> I'm not sure how it works... is there documentation for that?
Jeff,
OGR utility documentation is available off the OGR web page at:
http://www.gdal.org/ogr
> Or if Mapscript could be used that might be even
> better, though I really don't know how I could create new shapefiles from
> old ones but I'll look into it.
I don't know how to do that off hand in mapscript, but I think it has
the ability to create shapefiles. You might have to create all the fields
manually.
> Is it possible using ogr2ogr to output (as in your example) CFCC=A13 from
> every county shapefile into a single shapefile, or would I have to create
> separate output shapefiles for every county and then tile them?
As Stephen Woodbridge mentions, having lots of little shapefiles
with a tileindex isn't a bad thing. However, you can use the
ogr2ogr -append and -update to open an existing shapefile in update
mode, and append to the end of it if you really want to merge things.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
