Mapserver rpm mandrake 10.1
Lluís Garcia i Mestres
lluisgm at GMAIL.COM
Tue Mar 22 13:33:03 EST 2005
Lluís Garcia i Mestres to blaise
More options 7:32pm (0 minutes ago)
Hi Blaise,
Finally I found it. I was following the compilation example of Red Hat.
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RedHat9AndMapserver40
In this example you see:
cd php-4.3.3
make clean
./configure --enable-shared --with-regex=system --with-jpeg-dir=/usr
--with-png-dir=/usr --with-zlib --with-gd=/usr/local
--with-freetype-dir=/usr --enable-force-cgi-redirect --enable-dbase
--with-pdflib --with-mysql --with-config-file-path=/usr/local/php433/
--prefix=/usr/local/php433
make
sudo cp sapi/cgi/php /var/www/cgi-bin/php433
sudo make install
sudo cp php.ini-dist /usr/local/php433/php.ini
The error was to make "cp sapi/cgi/php /var/www/cgi-bin/php433" before
make install. Someone should change it.
The orders in httpd2.conf
> > AddType application/x-httpd-php-cgi .php .php4 .php3 .phtml
> > Action application/x-httpd-php-cgi /cgi-bin/php
were ok.
About the query and zoom problem, do you remember when it was posted
this trouble before? I've looking this last month and I couldn't find
it.
Lluís
On Tue, 22 Mar 2005 16:12:12 +0100, blaise <bpicinbono at worldonline.fr> wrote:
> Hi Lluis, have you found out ?
> Le mardi 22 Mars 2005 09:39, Lluís Garcia i Mestres a écrit :
> > Hi, I've achieved to compile php and mapserver by myself but I get two
> > erros:
> > - I add the following lines to httpd.conf but apache doesn't reconize php.
> You have to restart apache for any httpd.conf change to be considered. On
> mandrake, it should be either the command:
> #service httpd restart
> or
> #/etc/rc.d/init.d/httpd restart
> According to your apache conf file, the php filename must be "php" and be in
> the /cgi-bin directory of your web server (should be /var/www/cgi-bin/ on
> mandrake). What are the execution rights for this file ?
> Put a simple phpinfo.php page on your server and open it in your brower. At
> the begining, you should find this line :
> Server API : CGI
> > - On the other hand, I builded a map, just with mapserver, with
> > different layers and the position looks ok. But when I click on the
> > map using query or zoom function, it seems like mapserver send a point
> > 2-3 cm upper from where i have clicked.
> This is strange, there was a similar post a few days ago. Try to find it back
> on see if / how it has been solved. I would say troubles in your map EXTENT
> or SIZE ?
> Blaise
