Problems reading a TIF file (newbie question)
Brent Fraser
bfraser at GEOANALYTIC.COM
Tue Mar 22 14:15:34 EST 2005
Ray,
I see that Frank and blaise have already commented on the pathing and
file naming. The LAYER's DATA value is relative to the SHAPEPATH, so if you
have
SHAPEPATH "./data/"
your DATA statement should look like:
DATA "PAGE48.TIF" (or DATA "page48.tif" if you've followed Frank's
suggestion)
I'm not a Linux guy but you may want to try
SHAPEPATH "data/"
as I'm not sure Mapserver recognizes "./" as a relative path...
Brent
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, March 22, 2005 11:42 AM
Subject: Re: [UMN_MAPSERVER-USERS] Problems reading a TIF file (newbie
question)
> Brent,
> Thanks for your suggestion, no luck I'm afraid.
> The original tiff file is quite large (4724 x 6300 pixels), and I'm trying
> to display it in a much smaller window - what effect does this have?
> Ray
> On Tue, 22 Mar 2005 11:20:16 -0700, Brent Fraser <bfraser at GEOANALYTIC.COM>
> wrote:
> >Ray,
> > Try removing the PROJECTION definition from your map file. Since you
are
> >not moving data from one world coordinate system to another, the
PROJECTION
> >definition is not needed.
> > But if you want to do coordinate system stuff, likely the correct
> >PROJECTION definition (for the tiff file) would look like:
> > PROJECTION
> > "proj=tmerc"
> > "ellps=mod_airy"
> > "lon_0=-8"
> > "lat_0=53.5"
> > "k=1.000035"
> > "x_0=200000"
> > "y_0=250000"
> > END
> >Brent Fraser
> >From: "Ray" <ray at SUSTAINABLE.IE>
> >Sent: Tuesday, March 22, 2005 9:03 AM
> >Subject: [UMN_MAPSERVER-USERS] Problems reading a TIF file (newbie
question)
