libmap.dll documentation
Craig Miller
craig.miller at SPATIALMINDS.COM
Wed Mar 23 13:34:08 EST 2005
Thanks for the reply Frank. That's the response I thought I might get.
--Craig
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
Sent: Wednesday, March 23, 2005 10:26 AM
To: Craig Miller
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] libmap.dll documentation
On Wed, 23 Mar 2005 10:23:11 -0800, Craig Miller
<craig.miller at spatialminds.com> wrote:
> I'm having a bit of trouble locating documentation on using the libmap.dll
> from C++. Is there something available that I am missing in my search
> attempts?
Craig,
This question would likely be better posed on the mapserver-dev list.
What you are missing is that MapServer has no published C API for
you to use. It isn't really intended to be used this way. If you want to,
you are pretty much stuck digging through the code, and include files
to figure out what to do. Also, you will find you aren't very well
protected from the internals of structures and so forth.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
