making efficient map layers
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Mar 24 11:02:22 EST 2005
Ha! Even I can learn something new!
Ok you will bee to create a circle symbol and use that instead of SYMBOL 0
-Steve
Sean Gillies wrote:
> Symbol 0 is a single pixel symbol. You cannot size it. You'll need to
> use a different symbol for that first style.
> cheers,
> Sean
> On Mar 24, 2005, at 8:06 AM, Jeff Portwine wrote:
>> When I use a class definition like this, I only get the 1 pixel line, I
>> don't see it overlayed on the wider line.
>> CLASS
>> maxscale 99000
>> STYLE
>> SYMBOL 0
>> SIZE 3
>> COLOR 0 255 0
>> END
>> STYLE
>> SYMBOL 0
>> SIZE 1
>> COLOR 255 255 255
>> END
>> END
>> This class only draws the white line and ignores the green style...
>> I'm not
>> sure why.
>> -Jeff
>>>> - How do you go about changing the width of the different types of
>>>> roads? I assume each class of road is in a different layer and you
>>>> somehow manipulate the line width?
>>> In your class for the roads do something like this:
>>> CLASS
>>> EXPRESSION ...
>>> STYLE # first draw a 5 pixel wide green line
>>> SYMBOL 0 # built in circle symbol
>>> SIZE 5
>>> COLOR 0 255 0 # green
>>> END
>>> STYLE # then draw a 3 pixel wide white line on top of the green
>>> SYMBOL 0 # that leaves a 1 pixel border on each side of the
>>> white
>>> SIZE 3
>>> COLOR 255 255 255 # white
>>> END
>>> STYLE # then draw a 1 pixel wide black line down the center
>>> SYMBOL 0
>>> SIZE 1
>>> COLOR 0 0 0 # black
>>> END
>>> END
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
