How to make Moving Symbols using MapScript
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Sun Mar 27 07:55:31 EST 2005
Vdharan,
Not that I know of. I would be a great extension to Rosa or to Mapplet.
You might want to check on the Rosa list and see if anyone has done
this. If you get something like this working post a note back here
because I would be interested and I'm sure some others would be also.
-Steve
Vdharan wrote:
> Thankyou Stephen
> Is there any way to use the ROSA applet to implement moving of vehicles.?
> Is there any readymade functions to show a dynamic point?.
> Regards
> vdharan
> On Fri, 25 Mar 2005 08:34:55 -0500, Stephen Woodbridge
> <woodbri at SWOODBRIDGE.COM> wrote:
>>You should be able to do this is with a Java applet or a Flash
>>application. And you might be able to do it with xhtml and javascript.
>>The problem is you need to decide whether the application is going to
>>get its new data by push from the server or by polling the server for
>>updates. Since the map is not changing except when you pan or zoom it I
>>would separate the map image from the vehicles being tracked so your
>>client side application can request map changes based on the user input
>>and that you get a list of vehicles and their locations as a separate
>>stream of data from the server, then you Java, Flash, whatever to draw
>>the vehicles on top of the map. make the vehicle update a separate
>>thread and your all done.
>>-Steve W.
>> http://imaptools.com
>>vdharan wrote:
>>>Hello,
>>>Iam working on a vehicle tracking system. I want to show symbols
>>>representing vehicles to move in the map as and when the co-ordinate of
> the
>>>vehicle changes. I continuously get the co-ordinate of the vehicles at
>>>regular intervals. I want this to happen without refreshing the page.
>>>Can any one suggest me a way to do this.
>>>Iam using Redhat9 and PHP Mapscript.
>>>Best Regards,
>>>vdharan
