PIL PNG IOError
Ryan, Adam
ARyan at CO.LINN.OR.US
Wed Mar 30 12:29:06 EST 2005
Howard & Sean,
Thanks for the input. I'm using Howard's mapscript build and indeed turning
interlace off did solve the problem.
So, for PIL and PNG, I have added this to my pdf output script:
ofO = mapO.outputformat
ofO.setOption("INTERLACE","OFF")
Thanks for your continued help with my python endeavors. Cheers,
Adam
> -----Original Message-----
> From: Sean Gillies [mailto:sgillies at frii.com]
> Sent: Wednesday, March 30, 2005 7:41 AM
> To: Adam Ryan
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: PIL PNG IOError
> On Mar 29, 2005, at 3:58 PM, Adam Ryan wrote:
> > Hello to all,
> > I'm using Python Mapscript, ReportLab and PIL to generate
> PDF files on
> > Windows XP. I generate an image using mapscript, save it, and then
> > insert it into my pdf 'canvas':
> > Canvas.drawInlineImage(myfile,x,y,w,h)
> > If my mapfile outputformat is gif, no problem - I get a
> nice pdf file.
> > But
> > if my outputformat is png, I get an IOError:
> > File "C:\python23\lib\site-packages\PIL\ImageFile.py", line 192, in
> > load
> > IOError: unknown error when reading image file
> > Your thinking I'm posting to the wrong listserv right? Well, if I
> > take that png file and open it up in Micro$oft Paint and
> then save it,
> > my routine then works without a problem. So I compared the two png
> > files (before and after saving with Paint) with gdalinfo but got
> > identical results. I did notice that there was a file size
> decrease
> > after saving. But I don't know what else could be different
> about the
> > files. Any ideas?
> > Here are two examples of file size reduction with output format:
> > OUTPUTFORMAT
> > NAME png
> > DRIVER "GD/PNG"
> > MIMETYPE "image/png"
> > IMAGEMODE PC256
> > EXTENSION "png"
> > END
> > Reduction: 146kb to 137kb
> > outputformat
> > name "png"
> > driver "GD/PNG"
> > imagemode "RGB"
> > mimetype "image/png"
> > extension "png"
> > End
> > Reduction: 272kb to 205kb
> > Any sugestions would be grand. Cheers to all,
> > Adam
> Adam,
> Sorry, but I cannot reproduce this problem on Linux or on windows
> (Python 2.3.3 and PIL 1.1.5). PIL opens my mapscript PNG output just
> fine.
> Can you remind me of the source of your MapServer/mapscript software?
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
