Possible Proxy Server problem
John Bonk
bonk at EOSDATA.GSFC.NASA.GOV
Fri May 6 18:34:56 EDT 2005
Bart,
Setting http_proxy in the environment didn't work. I'll see if I can get
someone with permission to change the httpd.conf.
I'm not entirely sure the fire wall is to blame. All I know is that the
map file works on a machine without a fire wall.
Thank you for the response,
John
At 22:19 2005-05-06 +0200, Bart van den Eijnden wrote:
>Hi John,
>try specifying http_proxy as an environment variable. If you are using
>Apache use SetEnv in httpd.conf.
>See for more information:
>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=571
>Best regards,
>Bart
>On Fri, 06 May 2005 22:18:36 +0200, John Bonk <bonk at EOSDATA.GSFC.NASA.GOV>
>wrote:
>>We have been having trouble getting our mapserver to retrieve data from
>>remote machines. I suspect the problem may be connecting through our
>>proxy
>>server.
>>We have specified our proxy server in a .dodsrc file, and we have been
>>able
>>to retreive data from a dods server. But we still can't retrieve files
>>from wms servers.
>>Is there something special that has to be done to tell mapserv to go
>>through a proxy when retrieving data from a wms server?
>>The map file is below. It works on another machine that does not have a
>>proxy server.
>>Any help will be appreciated,
>>John
>>MAP
>> IMAGETYPE PNG
>> EXTENT -117.263 30.168 -83.774 51.676
>> units DD
>> DEBUG ON
>> SIZE 400 300
>> SHAPEPATH "data"
>> PROJECTION
>> "init=epsg:4326"
>> END
>> CONFIG PROJ_LIB /usr/local/share/proj/
>> WEB
>> IMAGEPATH '/local/tools/gdaac/TS2/www/workshop/tmp/'
>> IMAGEURL '/TS2/workshop/tmp/'
>> LOG '/local/tools/gdaac/TS2/www/workshop/debug.log'
>> METADATA
>> "wms_title" "WMS Test Demo"
>> "wms_onlineresource"
>>"http://g0dup05u.ecs.nasa.gov/TS2/cgi-bin/mapserv?"
>> "wms_abstract" "Test for mapserver"
>> "ows_schemas_location" "http://ogc.dmsolutions.ca"
>> END
>> END
>> # Start of scalebar
>> SCALEBAR
>> IMAGECOLOR 255 50 5
>> LABEL
>> COLOR 55 55 55
>> SIZE tiny
>> END
>> STYLE 1
>> SIZE 100 2
>> COLOR 0 0 0
>> UNITS MILES
>> INTERVALS 2
>> TRANSPARENT TRUE
>> STATUS EMBED
>> END
>> LAYER
>> NAME RTOPO
>> TYPE RASTER
>> units DD
>> OFFSITE 0 0 0
>> DEBUG ON
>> STATUS DEFAULT
>> PROJECTION
>> "init=epsg:4326"
>> END
>> CONNECTIONTYPE WMS
>> CONNECTION "http://globe.digitalearth.gov/viz-bin/wmt.cgi?"
>> METADATA
>> "wms_request" "GetMap"
>> "wms_name" "RTOPO"
>> "wms_server_version" "1.1.1"
>> "wms_srs" "EPSG:4326"
>> "wms_format" "image/png"
>> END
>> END
>> LAYER # MODIS raster layer begins here
>> METADATA
>> "wms_title" "test layer"
>> END
>> DEBUG ON
>> NAME modis
>> DATA RGB_mosaic_250m.tif
>> EXTENT -13053641.300000 3358256.867 -9325729.471 5752577.812
>> PROJECTION
>> "proj=eqc"
>> "lat_ts=0.0"
>> "x_0=0.0"
>> "y_0=0.0"
>> END
>> STATUS ON
>> TYPE RASTER
>> END # MODIS raster layer ends here
>> LAYER # States line layer begins here
>> METADATA
>> "wms_title" "test states layer"
>> END
>> DEBUG ON
>> NAME states
>> TYPE POLYGON
>> STATUS ON
>> DATA "statesp020"
>> PROJECTION
>> "proj=latlong"
>> "ellps=GRS80"
>> "datum=NAD83"
>> END
>> CLASS
>> NAME "states"
>> OUTLINECOLOR 60 60 60
>> SYMBOL 0
>> END
>> END # States line layer ends here
>>END # end of map file.
>>John Bonk
>>SSAI/NASA GES DISC
>>Phone:(301) 614-5280
>>Fax: (301) 614-5268
>>For more information about
>>the NASA GES DISC and its services:
>>http://daac.gsfc.nasa.gov/
>Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
John Bonk
SSAI/NASA GES DISC
Fax: (301) 614-5268
