Possible Proxy Server problem
Bart van den Eijnden
bartvde at XS4ALL.NL
Sat May 7 05:41:14 EDT 2005
Hi John,
For Microsoft IIS an environment variable works. For Apache you need to
use SetEnv in httpd.conf. Your problem does sound like a proxy problem to
me.
Let us know after httpd.conf gets changed.
Best regards,
Bart
On Sat, 07 May 2005 00:34:56 +0200, John Bonk <bonk at EOSDATA.GSFC.NASA.GOV>
wrote:
> Bart,
> Setting http_proxy in the environment didn't work. I'll see if I can get
> someone with permission to change the httpd.conf.
> I'm not entirely sure the fire wall is to blame. All I know is that the
> map file works on a machine without a fire wall.
> Thank you for the response,
> John
> At 22:19 2005-05-06 +0200, Bart van den Eijnden wrote:
>> Hi John,
>> try specifying http_proxy as an environment variable. If you are using
>> Apache use SetEnv in httpd.conf.
>> See for more information:
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=571
>> Best regards,
>> Bart
>> On Fri, 06 May 2005 22:18:36 +0200, John Bonk
>> wrote:
>>> We have been having trouble getting our mapserver to retrieve data from
>>> remote machines. I suspect the problem may be connecting through our
>>> proxy
>>> server.
>>> We have specified our proxy server in a .dodsrc file, and we have been
>>> able
>>> to retreive data from a dods server. But we still can't retrieve files
>>> from wms servers.
>>> Is there something special that has to be done to tell mapserv to go
>>> through a proxy when retrieving data from a wms server?
>>> The map file is below. It works on another machine that does not have
>>> a
>>> proxy server.
>>> Any help will be appreciated,
>>> John
>>> MAP
>>> IMAGETYPE PNG
>>> EXTENT -117.263 30.168 -83.774 51.676
>>> units DD
>>> DEBUG ON
>>> SIZE 400 300
>>> SHAPEPATH "data"
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> CONFIG PROJ_LIB /usr/local/share/proj/
>>> WEB
>>> IMAGEPATH '/local/tools/gdaac/TS2/www/workshop/tmp/'
>>> IMAGEURL '/TS2/workshop/tmp/'
>>> LOG '/local/tools/gdaac/TS2/www/workshop/debug.log'
>>> METADATA
>>> "wms_title" "WMS Test Demo"
>>> "wms_onlineresource"
>>> "http://g0dup05u.ecs.nasa.gov/TS2/cgi-bin/mapserv?"
>>> "wms_abstract" "Test for mapserver"
>>> "ows_schemas_location" "http://ogc.dmsolutions.ca"
>>> END
>>> END
>>> # Start of scalebar
>>> SCALEBAR
>>> IMAGECOLOR 255 50 5
>>> LABEL
>>> COLOR 55 55 55
>>> SIZE tiny
>>> END
>>> STYLE 1
>>> SIZE 100 2
>>> COLOR 0 0 0
>>> UNITS MILES
>>> INTERVALS 2
>>> TRANSPARENT TRUE
>>> STATUS EMBED
>>> END
>>> LAYER
>>> NAME RTOPO
>>> TYPE RASTER
>>> units DD
>>> OFFSITE 0 0 0
>>> DEBUG ON
>>> STATUS DEFAULT
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> CONNECTIONTYPE WMS
>>> CONNECTION "http://globe.digitalearth.gov/viz-bin/wmt.cgi?"
>>> METADATA
>>> "wms_request" "GetMap"
>>> "wms_name" "RTOPO"
>>> "wms_server_version" "1.1.1"
>>> "wms_srs" "EPSG:4326"
>>> "wms_format" "image/png"
>>> END
>>> END
>>> LAYER # MODIS raster layer begins here
>>> METADATA
>>> "wms_title" "test layer"
>>> END
>>> DEBUG ON
>>> NAME modis
>>> DATA RGB_mosaic_250m.tif
>>> EXTENT -13053641.300000 3358256.867 -9325729.471 5752577.812
>>> PROJECTION
>>> "proj=eqc"
>>> "lat_ts=0.0"
>>> "x_0=0.0"
>>> "y_0=0.0"
>>> END
>>> STATUS ON
>>> TYPE RASTER
>>> END # MODIS raster layer ends here
>>> LAYER # States line layer begins here
>>> METADATA
>>> "wms_title" "test states layer"
>>> END
>>> DEBUG ON
>>> NAME states
>>> TYPE POLYGON
>>> STATUS ON
>>> DATA "statesp020"
>>> PROJECTION
>>> "proj=latlong"
>>> "ellps=GRS80"
>>> "datum=NAD83"
>>> END
>>> CLASS
>>> NAME "states"
>>> OUTLINECOLOR 60 60 60
>>> SYMBOL 0
>>> END
>>> END # States line layer ends here
>>> END # end of map file.
>>> John Bonk
>>> SSAI/NASA GES DISC
>>> Phone:(301) 614-5280
>>> Fax: (301) 614-5268
>>> For more information about
>>> the NASA GES DISC and its services:
>>> http://daac.gsfc.nasa.gov/
>> Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
> John Bonk
> SSAI/NASA GES DISC
> Fax: (301) 614-5268
