International text characters
Janeks Kamerovskis
janeks.kamerovskis at SILVA.LV
Wed May 18 09:50:54 EDT 2005
Thanks for answer!
Probably dummy question:
How to get to know what kind of encoding have f.ex. an *.dbf file of
shapefiles?
brgds
Janeks
> -----Original Message-----
> From: Mario Basa [mailto:mario.basa at gmail.com]
> Sent: Tuesday, May 17, 2005 5:57 PM
> To: Janeks Kamerovskis
> Subject: Re: [UMN_MAPSERVER-USERS] International text characters
> Hello Jaeks,
> Basically, that is what the "ENCODING" parameter of Mapserver does:
> convert the i18n text into UTF-8 using libiconv. If you did convert
> the text into UTF-8 already, you don't have to place the "ENCODING"
> parameter anymore in your Layer definition.
> Really hope this helps.
> mario.
> On 5/17/05, Janeks Kamerovskis <janeks.kamerovskis at silva.lv> wrote:
> > Then what you will tell regarding this situation:
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0404/msg0
> 0162.html
> > brgds
> > Janeks
> > > From: UMN MapServer Users List
> > > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Mario Basa
> > > Sent: Tuesday, May 17, 2005 5:04 PM
> > > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > > Hello,
> > > The first thing that usually has to be done when encountering problems
> > > with international text characters is to check if the character
> > > encoding used is supported by iconv. You can check it here:
> > > http://www.gnu.org/software/libiconv/
> > > If it is, then it is just a matter of finding the right font set that
> > > can handle the i18n text, which you most probably have in your
> > > computer already.
> > > regards
> > > mario
> > > yokohama,japan.
> > > On 5/17/05, Robert Jones <xbobwjones at hotmail.com> wrote:
> > > > Hi
> > > > I posted a couple of weeks ago and have not been able to solve
> > > my problem
> > > > with international text characters not displaying properly..
> > > > I am using a shapefile with text fields encoded in LATIN1,
> and am almost
> > > > certain that the truetype font I am using to label supports
> > > these characters.
> > > > Can anyone help? I stuck..
> > > > I'm thinking it must have something to do with either the font,
> > > libiconv, or
> > > > ms4w - which I used to set up mapserver. Has anyone else
> experienced
> > > > similar problems with ms4w?
> > > > I am setting up the the layer as follows:
> > > > #Towns layer
> > > > LAYER
> > > > NAME "bart_caps2"
> > > > GROUP "twn"
> > > > STATUS ON
> > > > DATA "twn_p"
> > > > TYPE POINT
> > > > CLASSITEM "CODE"
> > > > UNITS METERS
> > > > SIZEUNITS PIXELS
> > > > MINSCALE 0
> > > > MAXSCALE 58936139
> > > > LABELITEM "COMMENT"
> > > > LABELCACHE ON
> > > > POSTLABELCACHE FALSE
> > > > TOLERANCE 0
> > > > TOLERANCEUNITS PIXELS
> > > > TRANSPARENCY 100
> > > > METADATA
> > > > "Description" "bart_twn"
> > > > END
> > > > #end metadata
> > > > PROJECTION
> > > > "init=epsg:4326"
> > > > END
> > > > #end projection
> > > > CLASS
> > > > NAME "bart_twn"
> > > > EXPRESSION ([CODE] > 70 AND [CODE] < 72)
> > > > LABEL
> > > > TYPE TRUETYPE
> > > > FONT ARIAL
> > > > ENCODING LATIN1
> > > > SIZE 10
> > > > POSITION AUTO
> > > > OFFSET 0 0
> > > > COLOR 1 1 1
> > > > OUTLINECOLOR 255 255 255
> > > > PARTIALS TRUE
> > > > FORCE FALSE
> > > > END
> > > > STYLE
> > > > SYMBOL 7
> > > > COLOR 255 0 0
> > > > OUTLINECOLOR 0 0 0
> > > > BACKGROUNDCOLOR 0 0 0
> > > > SIZE 6
> > > > ANTIALIAS FALSE
> > > > END
> > > > #end style
> > > > END
> > > > #end class
> > > > END
> > > > #END LAYER
> > > > Thanks
> > > > Rob
