Problems installing PHP Mapscript - HELP!
Dan Taylor
logicalgenetics at GMAIL.COM
Thu May 19 12:02:32 EDT 2005
I am currently trying to install php mapscript on a Fedora 2 machine.
I have done the following...
./configure --with-ogr --with-gdal --with-jpeg --with-proj
--with-php=/usr/include/php/
make
su
cp -f mapserv /var/www/cgi-bin/mapserv40
cp -f mapscript/php3/php_mapscript.so /usr/lib/php4/
And used the following PHP snippet to test it...
<?php
if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
dl("php_mapscript.dll");
else
dl("php_mapscript.so");
phpinfo();
The output of phpinfo() is displayed correctly, but the php_mapscript
module is not loaded. I can confirm this by adding...
extension_loaded("php_mapscript")
... to the script. I'm using PHP version 4.3.10-2.4. I haven't
observed any errors when compiling mapserver using the commands above.
I've also restarted httpd several times using "service httpd
restart".
Here's the output: http://213.210.59.141/php-mapserver-test.php
What have I forgotten?
Cheers,
Dan
Dan Taylor
Software Development Engineer, JTL Systems Ltd
PhD Student, Reading University, UK
http://www.logicalgenetics.com
