getfeatureinfo and feature_count order
Howard Mark
MHoward at SPACEIMAGING.COM
Thu May 19 12:50:20 EDT 2005
I have a project where I need to limit the number of features returned by getfeatureinfo. I want the set of features returned to be selected by attribute precedence - e.g. most recent, highest score..... The data is in shapefile format with a shptree index. The data is in no particular order. I assume that the getfeatureinfo routine just traverses the index file and stops at record n where n=feature_count. I also assume that the index file is in the same order as the source shapefile; and that one way to get what I want is to build the shapefile in the correct order. So I have four questions:
1. Are my assumptions correct?
2. Is there a way to specify the order of retrieval in the map file- or another simple way with the configuration or URL string?
3. Failing that - is there a way to build an index ordered by feature attribute(s)?
4. Failing that is there a way to re-order a shapefile by feature attributes(s)?
Unfortunately the shapefile is dynamic - we get a new one daily.
TIA for any help!!!!
Mark
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
