Progress bar didn't stop in FireFox and Netscape
Emilio Mayorga
emiliom at U.WASHINGTON.EDU
Mon May 23 01:29:37 EDT 2005
I've had the same problem in Firefox and Mozilla, using a
javascript/DHTML application based on the Itasca demo, with lots of
modifications. The progress bar looks active, the swirling browser icon
(in Firefox) keeps going around, and when you move the cursor over a
part of the browser other than the page, the cursor turns to the waiting
cursor. I haven't found the exact source of the error; I gave up a while
ago. Here's my application, if you're curious:
http://geo.garrobo.org/mapache/eng/ecosist_ind.html
-Emilio Mayorga
Date: Sun, 22 May 2005 18:15:02 +0200
Subject: Re: Progress bar didn't stop in FireFox and Netscape
Hi Paul,
that's also true, but the problem seemed to be that the javascript code
which was used for the application was not cross-browser.
It used things like window.event, so IE specific JS code.
Best regards,
Bart
On Sun, 22 May 2005 18:10:22 +0200, Paul Spencer
<pspencer at DMSOLUTIONS.CA> wrote:
> There is a known problem with Mozilla-based browsers (the problem is in
> Mozilla, not MapServer) that causes this when the source of an image is
> changed after the page has loaded. The application is likely working
> just fine.
> Paul
> Bart van den Eijnden wrote:
>> What are you using as a client application? Mapserver is just a server.
>> Are you using something like the Itasca demo?
>> Try looking in the javascript window of Firefox (Tools->Javascript
>> console), this probably has something to do with a javscript error.
>> Best regards,
>> Bart
>> On Sun, 22 May 2005 14:48:10 +0200, beny santoso
>> <beny.santoso at GMAIL.COM>
>> wrote:
>>> Hi all,
>>> My application (using mapserver) running well when i browse with IE
>>> and Opera. But in FireFox and Netscape, progress bar didn't stop when
>>> process finish. Then maptool (zoom, pan etc) didn't work.
>>> Any help? Thank's
>>> Regards,
>>> Beny
