mix projection unit.
vincent.dacol
vincent.dacol at LAPOSTE.NET
Mon May 23 10:52:19 EDT 2005
Hello,
I have a little trouble in using Mapserver. I want mix datas
in degree and meters unit.
Is it possible with mapserver? I have read on the FAQ it's
not, because the projection unit must be the same as the
projected data.
Thanks for the help.
Accédez au courrier électronique de La Poste : www.laposte.net ;
3615 LAPOSTENET (0,34/mn) ; tél : 08 92 68 13 50 (0,34/mn)
