OGR Virtual file and query
Wouter Schaubroeck
wouter.schaubroeck at GMAIL.COM
Mon May 23 19:55:46 EDT 2005
Hi all,
Is it possible to perform a query on data that is connected through an
OGR Virtual file?
Is it possible that I'm doing something wrong here?
I use the ovf to connect to a dbf, and the points are visible on my map,
so that ain't the problem.
This is the layer in my map file:
LAYER
NAME "Herten"
TYPE POINT
METADATA
"DESCRIPTION" "Reeën"
END
CONNECTIONTYPE OGR
CONNECTION "virtual.ovf"
DATA "GSM00837"
STATUS DEFAULT
PROJECTION
"init=epsg:4313"
END
LABELITEM "OBSERVATIE"
CLASS
TEMPLATE
"C:\ms4w\apps\mum2_php_mapscript\herten\punten_query.html"
SYMBOL cir
SIZE 6
COLOR 255 0 0
LABEL
COLOR 255 255 255
SHADOWCOLOR 0 0 0
SHADOWSIZE 2 2
FONT arial-bold
SIZE SMALL
POSITION AUTO
BUFFER 3
END
END
and this is my query template file:
<PRE>
Observatie
<br>[OBSERVATIE]</br>
</PRE>
Best regards
Wouter Schaubroeck
