OGR Join and class {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Thu May 26 16:55:46 EDT 2005
I would like to define classes based on an OGR Joined (ODBC) column.
I was not able to make the class definitions.
My layer definition looks like:
LAYER
NAME test
CONNECTIONTYPE OGR
CONNECTION kafold.shp
DATA "SELECT kafold.*, ms.* FROM kafold LEFT JOIN
'ODBC:admin/xxx at mydb'.ms ON kafold.hrsz=ms.hrsz"
TYPE POLIGON
STATUS DEFAULT
CLASSITEM "ms.MYCOL"
CLASS
EXPRESSION /x/
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
END
If I remove CLASSITEM and EXPRESSION line the layer is drawn, so the DATA
definition is good.
I also tried to to remove CLASSITEM and give an expression like
EXPRESSION ('[ms.MYCOL]' = 'x')
I get an error massage in the apache error log
libpng warning Incomplete compressed datastream in iCCP chunk
Any idea?
Thanks
Zoltan
