Mapscript .NET, compile
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu May 26 18:08:10 EDT 2005
Hi Sean,
I was using 4.6 beta1. Mapscript.i version is: $Id: mapscript.i,v 1.198
2005/02/08 17:34:46 sean Exp $.
It does compile without warnings, but I ran into a few runtime exceptions,
but maybe that's a problem of the C# code of the utilities.
I will try 4.6 beta2 soon.
Best regards,
Bart
On Thu, 26 May 2005 23:41:35 +0200, Sean Gillies <sgillies at frii.com> wrote:
> On May 26, 2005, at 11:40 AM, Bart van den Eijnden wrote:
>> Hi list,
>> I finally tried to compile Mapscript .NET and I thought I'd share the
>> process I went through and ask a few questions. Let me start with the
>> questions :-) :
>> 1) why won't the generated mapscript_wrap.c file compile out of the box
>> (see below)?
> Bart, you're leaving out some crucial information ... which MapServer
> version is this? I don't see the call to msSetup in mapscript_wrap.c
> with 4.6beta2. I'm using SWIG 1.3.21 and testing with Mono.
>> 2) what is the difference between mapscript.dll and
>> mapscript_csharp.dll?
> I did a 'strings mapscript.dll' ... it contains the functions of libmap.
> The csharp dll is the C# wrapper module.
>> 3) using the utilities eg shpdump I do get a few unhandled exceptions.
>> Is
>> that supposed to be the case?
>> Shape 1 has 1 part(s)
>> bounds (362153.9375, 3651581.75) (413756.1875, 3708708)
>> Unhandled Exception: System.NullReferenceException: Object reference not
>> set to
>> an instance of an object.
>> at ShapeDump.Main(String[] args)
> No, I don't think it should raise exceptions.
> I'm not a C# user at all, but I am able to get the module in 4.6beta to
> compile without warnings on Linux using the Makefile.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://zcologia.com
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
