Implementing line and polygon layers.
Owens, Ryan J NWD02 CONTRACTOR
Ryan.J.Owens at NWO02.USACE.ARMY.MIL
Tue May 31 15:19:12 EDT 2005
Please disregard this message. I learned that my Flash viewer only accepts
four layers, and I have obviously exceeded that amount with this map file.
Thanks,
Ryan
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Owens, Ryan J NWD02 CONTRACTOR
Sent: Tuesday, May 31, 2005 1:45 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Implementing line and polygon layers.
Hello list serve,
I have a map file that I am trying to implement a number of layers in (line,
raster, and polygon). I have a "river" layer, a "lakes" layer, a
"state_shapes" layer and a "basin" layer. For some reason I am unable to
implement the "lakes" and "states_shapes" layers simultaneously. Could
someone scan over my map file code to see if I've made any errors? I can
implement each layer individually, but when combined, one of the layers goes
away.
Thanks in advance.
Ryan
MAP
NAME FMV_
EXTENT -535681 116823 1337533 1458918
WEB
log "./test.log"
TEMPLATE "test_template.html"
IMAGEPATH "./tmp/"
IMAGEURL "[domain]/fmv/test/tmp/"
END
DEBUG ON
OUTPUTFORMAT
NAME swf
DRIVER "SWF"
MIMETYPE "application/x-shockwave-flash"
EXTENSION "swf"
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
END
IMAGETYPE swf
SIZE 460 500
SHAPEPATH "data"
IMAGECOLOR 255 255 255
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER
NAME "basin"
DATA basin_alb.TIF
STATUS DEFAULT
TYPE RASTER
# PROJECTION
# END
END
LAYER
NAME "river"
DATA missouri_river
STATUS DEFAULT
TYPE LINE
METADATA
"SWFDUMPATTRIBUTES" "NAME,LENGTH"
END
CLASS
COLOR 0 0 254
END
END
LAYER
NAME "lakes"
DATA mainstem_lakes
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 0 0 0
OUTLINECOLOR 0 0 0
END
METADATA
"SWFDUMPATTRIBUTES" "LAKE_NAME,AREA"
END
END
LAYER
NAME "state_shapes"
DATA states
STATUS DEFAULT
TYPE LINE
CLASS
COLOR 0 0 0
END
END
# LAYER
# NAME dcp
# DATA dcps
# STATUS DEFAULT
# TYPE POINTS
# METADATA
# "SWFDUMPATTRIBUTES,MRADS_ID"
# END
# CLASS
# NAME "POINTS"
# STYLE
# SYMBOL "circle"
# SIZE 1
# COLOR 0 0 0
# END
# END
END
#End of LAYER DEFINITIONS ---------------------------------------------
END # end of map file/object^M
