error accessing postgis
Russ Bradford
Russ.Bradford at CSIRO.AU
Mon Nov 28 20:11:52 EST 2005
I have had this same problem. I could not do even the most simple SQL
query using MapServer and a postgis postgreSQL database. There was no
"oid" column - even though there was one in the database.
I have just overcome this problem (which was more related to my
inexperience than anything else) by using the following definition for
the DATA tag:
DATA "geom from (select column_a, oid, geom from tablename where
column_name = 'value') as foo using unique oid using srid = 4326)"
I use column_a as the LABELITEM. In short I have found that in the DATA
definition you need to specify every column that you will be using
(specifically "oid").
Hope this helps.
Cheers, Russ.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Stephen Woodbridge
Sent: Tuesday, 29 November 2005 3:02 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] error accessing postgis
By default posgres 8.1 does not build oids any more. You need to change
you query to specify some other unique column for mapserver. You can add
a serial column and make it the primary key then reference that.
-Steve W.
Rick Schumeyer wrote:
> Mapserver [v4.6.1] returns an error when I try to access a postgis
> [1.0.4] database. (Postgis is installed with postgresql 8.1.0). I
> assume my mapfile is incorrect, but I'm not sure what the mistake is.
> Here is the error:
> msDrawMap(): Image handling error. Failed to draw layer named 'sdata'.
> prepare_database(): Query error. Error executing POSTGIS DECLARE (the
> actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(iarea)),'NDR'),OID::text from sdata
> WHERE iarea && setSRID('BOX3D(-180 -135,180 135)'::BOX3D,
> find_srid('','sdata','iarea') )'
> Postgresql reports the error as 'ERROR: column "oid" does not exist '
> The relevant portion of my mapfile:
> LAYER
> NAME "sdata"
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=gtest user=postgres host=localhost"
> DATA "iarea from sdata"
> TYPE line
> STATUS default
> CLASS
> NAME "State Line"
> STYLE
> SYMBOL "BigLine"
> SIZE 2
> COLOR 255 0 0
> END
> END
> END
> The definition of the table "sdata":
> Table "public.sdata"
> Column | Type | Modifiers
> id | integer | not null default
> nextval('sdata_id_seq'::regclass)
> instrument | character varying(20) |
> begintime | timestamp with time zone |
> endtime | timestamp with time zone |
> iarea | geometry |
> filename | character varying(512) |
> Indexes:
> "idx_iarea" gist (iarea)
> Check constraints:
> "enforce_dims_iarea" CHECK (ndims(iarea) = 2)
> "enforce_geotype_iarea" CHECK (geometrytype(iarea) =
> 'POLYGON'::text
> OR iarea IS NULL)
> "enforce_srid_iarea" CHECK (srid(iarea) = 4326)
