Mapscript installation problem
Johannes Weigel
weigel at ECOGIS.DE
Sun Oct 2 08:16:38 EDT 2005
Hi everybody,
I' trying to run Mapserver 4.6.1 with apache 2.0.54 and PHP 5.0.5 on a
Mandrake 10.0 linux machine. I followd the verbose linux install howto
(http://ms.gis.umn.edu/docs/howto/verboselinuxinstall) which worked
quite well, and finally I got everything installed. Apache with PHP are
active, and Mapserver is working, as I get an answer to my cgi-request
("No query information to decode. QUERY_STRING is set, but empty.")
Then I tried to run a demo application (hello.phtml from
http://www.mobilegeographics.com/mapserver/) but I don't get a map
display. Instead only a part of the php request is displayed: draw();
$image_url=$image->saveWebImage(); ?>
(The HTML code starts as following:
<?php
dl("php_mapscript.so");
$map_file="./hello.map";
$map = ms_newMapObj($map_file);
$image=$map->draw();
Can anybody tell me what is the problem? I even copied the
php_mapscript.so into the appropriate php extensions directory. To
compile PHP and Mapserver I used the following options:
PHP:
./configure \
--prefix=/usr/local/apache2/php \
--with-php-regex=/usr/local/apache2/php/include/php/regex \
--disable-cgi \
--with-config-file-path=/usr/local/apache2/php \
--with-openssl \
--with-kerberos \
--with-zlib \
--with-bz2 \
--with-curl \
--enable-dbase \
--enable-ftp \
--with-gd \
--with-pgsql \
--with-xsl \
--with-mysql \
--with-gettext
Mapserver:
./configure \
--with-proj=/usr/local \
--with-geos=/usr/local/bin/geos-config \
--with-ogr=/usr/local/bin/gdal-config \
--with-gdal=/usr/local/bin/gdal-config \
--with-postgis=/usr/local/pgsql/bin/pg_config \
--with-curl-config=/usr/bin/curl-config \
--with-httpd=/usr/local/apache2/bin/httpd \
--with-gd=/usr/local \
--with-php=/usr/local/apache2/php \
--with-wms \
--with-wfs
Best regards,
Johannes
Johannes Weigel
ECOGIS Geomatics
Bergstr. 36
D-53332 Bornheim
http://www.ecogis.de
weigel at ecogis.de
