Chloropleth maps with Mapserver
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Sun Oct 2 09:01:12 EDT 2005
Jason,
There has been a lot of discussion on this lately, search the archives
for subject "Proposed RFC on COLORRAMP Support" on the mapserver-dev
list. The issue of where or not there is a way to define the number of
color regions dynamically has been an issue of debate. There is some
feeling that this should be done using mapscript to dynamically generate
N number of classes.
-Steve W.
Jason Pickering wrote:
> I am currently evaluating the capabilities of MapServer to retrieve
> data from a Postgresql database and display it on a chlorpleth map.
> For instance, I have data like:
> Area IndicatorValue
> Area 1 10
> Area 2 20
> Area 3 15
> Area 4 20
> etc etc
> Each region will be represented by a color, depending on what the
> value is in the "IndicatorValue" column. The users need to be able to
> select (dynamically) how many color regions will be displayed on the
> map, and what the value range of each color is.
> I have searched high and low through the archives, and Google, but
> can't seem to find a definitive answer, or better yet, and example of
> how this can be done with Mapserver.Any pointers would be most
> welcome.
> Best regards,
> JPP
