Problems with ArcInfo Binary grid...
Frank Warmerdam
warmerdam at POBOX.COM
Wed Oct 5 10:53:25 EDT 2005
On 10/5/05, Carlo Calvino <carlo.calvino at email.it> wrote:
> If the use of *.lyr is not possible, is there any other possibilities?
> For example, what about *.clr files? Is there a tool to convert
> from .clr/.lyr to a map file?
Carlo,
Yes, .clr files *should* work and mapserver should color the raster
according to the .clr file if is present. You can check quickly whether
the colortable is found by using gdalinfo on the binary grid.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
