transparent overlay and alpha blending
Frank Warmerdam
warmerdam at POBOX.COM
Thu Oct 6 14:43:09 EDT 2005
On 10/6/05, Jerl Simpson <jerl.simpso at gmail.com> wrote:
> Hello,
> I'm not sure if I'm posting the right place or not,but here goes.
> I use Mapserver to generate maps (of course) I have another program that
> grabs these maps, adds some dynamic content, and spits them out to a
> browser. The other program is a C program and uses the GD library to
> manipulate the images.
> My output format is:
> OUTPUTFORMAT
> NAME gif
> DRIVER "GD/GIF"
> MIMETYPE "image/gif"
> IMAGEMODE RGBA
> EXTENSION "gif"
> END
> So I should be able to support alpha blending.
> The problem, is when I add my layer to this gif, the area that should be
> blended is completely opaque.
> I can't seem to find anywhere where this reverts to a paletted image, so
> I'm lost.
> If anyone can help me, I'd be greatly appreciative.
> I realize there's not much information to go on, so I'll wait to hear from
> someone before sending specific information.
Jerl,
There is no such thing as an RGBA (or RGB) GIF file. Ideally
MapServer would realize this (sooner) and blow a gasket when
it encounters your OUTPUTFORMAT declaration. If you submit
a bug report and see that it is assigned to me I'll try and fix that.
If you want RGB or RGBA output format use a format that supports
it like PNG.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
