GDAL/OGR 1.3.1 Released - Building failed on Windows with
MinGW
Tamas Szekeres
szekeres.tamas at FREEMAIL.HU
Thu Oct 6 16:36:47 EDT 2005
David,
Without being concerned with MinGW/Msys the library successfully compiles
on Windows using VS7. The only problem was with the compilation of the
SWIG C# library that could finally be succeeded with the method described
in:
http://bugzilla.remotesensing.org/show_bug.cgi?id=949
Tamas Szekeres
On Thu, 6 Oct 2005 21:05:17 +0400, david techer <davidtecher at YAHOO.FR>
wrote:
>Tamas is right!
>I tryed myself to compil it on Windows using MinGW and Msys but without
any success.
>BTW, is there someone who can give me the commands he used to compil on
Windows
>with MinGW/Msys. There is GDAL FAQ and the mailing-list and I tryed from
the archive
>but if someon can just give to me the commands he did...
>Since I'm used to compiling/building PostgreSQL/PostGIS/Geos/Proj on
windows, if I do it
>for gdal it will be a great help...
>Thanks.
>Regards.
>David.
>--david;
>Jean David TECHER
>e-mail: davidtecher(at)yahoo(dot)fr
>site: http://techer.pascal.free.fr/postgis/
>Tamas Szekeres a écrit :
>>Frank,
>>Thank you for the release. However in order to compile SWIG with C# some
>>modifications should be made in the makefile and some typemaps should be
>>added.
>>Tamas
>>On Tue, 4 Oct 2005 15:32:51 -0400, Frank Warmerdam <warmerdam at POBOX.COM>
>>wrote:
>>>Folks,
>>>I am pleased to announce the release of GDAL/OGR 1.3.1. This is mostly
a
>>>bug fix release, though there are a few new and improved drivers.
>>>Source:
>>> http://www.gdal.org/dl/gdal-1.3.1.tar.gz
>>> http://www.gdal.org/dl/gdal131.zip
>>>Docs / Web site:
>>> http://www.gdal.org/dl/gdal131doc.zip
>>>Test Suite:
>>> http://www.gdal.org/dl/gdalautotest-1.3.1.tar.gz
>>>The major news with this release is that the "Next Generation" Perl,
>>Python
>>>and Ruby bindings are now considered ready to use, though I'm sure there
>>will
>>>be some additional improvements to them in the coming months. I would
>>like to
>>>give out a special thank you to Ari Jolma (perl), Charlie Savage (Ruby),
>>>Kevin Ruland (Python + overall NG work) and Howard Butler who have put
in
>>a
>>>huge amount of effort on these bindings. If we can get champions for
>>Java,
>>>C# and PHP that are willing to brave the dark depths of SWIG, I'm sure
we
>>can
>>>make good progress on them too.
>>>Best regards,
>>>I set the clouds in motion - turn up | Frank Warmerdam,
>>warmerdam at pobox.com
>>>light and sound - activate the windows | http://pobox.com/~warmerdam
>>>and watch the world go round - Rush | Geospatial Programmer for Rent
>>>GDAL 1.3.1 - Overview of Changes
>>>Next Generation SWIG Wrappers (GDAL and OGR):
>>>- Python, Perl and Ruby bindings considered to be ready to use.
>>>- C#, Java, PHP are at best initial prototypes.
>>>- Added configure options for most NG options.
>>>PCRaster Driver:
>>>- libcsf is now included as part of GDAL.
>>>- PCRaster enabled by default on win32.
>>>- --with-pcraster=internal option now supported on unix (but not yet
>>default)
>>>VSI Virtualization:
>>>- The "large file API" (VSI*L) has been re-engineered to allow
installing
>>> additional file handlers at runtime.
>>>- Added "in memory" VSI handler so that now any driver using VSI*L
>>> functions for data access can operate on in-memory files.
>>>- PNG, JPEG and GeoTIFF drivers upgraded to work with in-memory support.
>>>Raster Attribute Tables:
>>>- Implemented new Raster Attribute Tables support. See the
>>> GDALRasterAttributeTable class for more information.
>>>Erdas Imagine Overviews:
>>>- Erdas Imagine driver upgraded to support building internal overviews.
>>>- Generic overview handler updated to support overviews in Erdas Imagine
>>> format for any file format. Set USE_RRD config option to YES to
>>enable.
>>>gdalwarp:
>>>- Added proper support for "unified source nodata", so the -srcnodata
>>> switch works well.
>>>RIK Driver:
>>>- New Swedish format driver implemented by Daniel Wallner.
>>>JPEG Driver:
>>>- Substantial improvements to EXIF support.
>>>MrSID Driver:
>>>- Updated with proper JPEG2000 support as JP2MRSID driver, including
>>> encoding with ESDK.
>>>- Updated to support MrSID Version 5.x SDKs.
>>>PNG Driver:
>>>- Fixed serious bugs with 16bit file support.
>>>- Added NODATA_VALUES to identify RGB sets that indicate a nodata pixel.
>>>OGR 1.3.1 - Overview of Changes
>>>Reference Counting:
>>>- OGRSpatialReference and OGRFeatureDefn now honour reference counting
>>> semantics.
>>>- Note that, especially for the OGRFeatureDefn, it is now critical that
>>> all drivers be careful with reference counting. Any OGR drivers not
in
>>> the core distribution will likely crash if not updated.
>>>ESRI Personal Geodatabase Driver:
>>>- New driver implemented for ESRI Personal Geodatabase (.mdb) files.
>>>- Uses ODBC, enabled by default on win32.
>>>ODBC Driver:
>>>- Updated to support binary fields.
>>>- Updated to support WKB geometry fields.
>>>- Updated to support DSN-less connections.
>>>S57 Driver:
>>>- Added support for Inland Waterways, and Additional Military Layers
>>profiles
