GDAL/OGR 1.3.1 Released - Building failed on Windows with
MinGW
Tamas Szekeres
szekeres.tamas at FREEMAIL.HU
Thu Oct 6 17:44:40 EDT 2005
Yes, and using nmake.
Tamas
On Fri, 7 Oct 2005 02:53:23 +0400, david techer <davidtecher at YAHOO.FR>
wrote:
>Ok Tamas thanks you
>By VS7 you mean Visual Studio 7?
>--david;
>Jean David TECHER
>e-mail: davidtecher(at)yahoo(dot)fr
>site: http://techer.pascal.free.fr/postgis/
>Tamas Szekeres a écrit :
>>David,
>>Without being concerned with MinGW/Msys the library successfully compiles
>>on Windows using VS7. The only problem was with the compilation of the
>>SWIG C# library that could finally be succeeded with the method described
>>in:
>>http://bugzilla.remotesensing.org/show_bug.cgi?id=949
>>Tamas Szekeres
>>On Thu, 6 Oct 2005 21:05:17 +0400, david techer <davidtecher at YAHOO.FR>
>>wrote:
>>>Tamas is right!
>>>I tryed myself to compil it on Windows using MinGW and Msys but without
>>any success.
>>>BTW, is there someone who can give me the commands he used to compil on
>>Windows
>>>with MinGW/Msys. There is GDAL FAQ and the mailing-list and I tryed from
>>the archive
>>>but if someon can just give to me the commands he did...
>>>Since I'm used to compiling/building PostgreSQL/PostGIS/Geos/Proj on
>>windows, if I do it
>>>for gdal it will be a great help...
>>>Thanks.
>>>Regards.
>>>David.
>>>--david;
>>>Jean David TECHER
>>>>Frank,
>>>>Thank you for the release. However in order to compile SWIG with C#
some
>>>>modifications should be made in the makefile and some typemaps should
be
>>>>added.
>>>>Tamas
>>>>On Tue, 4 Oct 2005 15:32:51 -0400, Frank Warmerdam
<warmerdam at POBOX.COM>
>>>>wrote:
>>>>>Folks,
>>>>>I am pleased to announce the release of GDAL/OGR 1.3.1. This is
mostly
>>a
>>>>>bug fix release, though there are a few new and improved drivers.
>>>>>Source:
>>>>>http://www.gdal.org/dl/gdal-1.3.1.tar.gz
>>>>>http://www.gdal.org/dl/gdal131.zip
>>>>>Docs / Web site:
>>>>>http://www.gdal.org/dl/gdal131doc.zip
>>>>>Test Suite:
>>>>>http://www.gdal.org/dl/gdalautotest-1.3.1.tar.gz
>>>>>The major news with this release is that the "Next Generation" Perl,
>>>>Python
>>>>>and Ruby bindings are now considered ready to use, though I'm sure
there
>>>>will
>>>>>be some additional improvements to them in the coming months. I would
>>>>like to
>>>>>give out a special thank you to Ari Jolma (perl), Charlie Savage
(Ruby),
>>>>>Kevin Ruland (Python + overall NG work) and Howard Butler who have put
>>in
>>>>a
>>>>>huge amount of effort on these bindings. If we can get champions for
>>>>Java,
>>>>>C# and PHP that are willing to brave the dark depths of SWIG, I'm sure
>>we
>>>>can
>>>>>make good progress on them too.
>>>>>Best regards,
>>>>>I set the clouds in motion - turn up | Frank Warmerdam,
>>>>warmerdam at pobox.com
>>>>>light and sound - activate the windows | http://pobox.com/~warmerdam
>>>>>and watch the world go round - Rush | Geospatial Programmer for
Rent
>>>>>GDAL 1.3.1 - Overview of Changes
>>>>>Next Generation SWIG Wrappers (GDAL and OGR):
>>>>>- Python, Perl and Ruby bindings considered to be ready to use.
>>>>>- C#, Java, PHP are at best initial prototypes.
>>>>>- Added configure options for most NG options.
>>>>>PCRaster Driver:
>>>>>- libcsf is now included as part of GDAL.
>>>>>- PCRaster enabled by default on win32.
>>>>>- --with-pcraster=internal option now supported on unix (but not yet
>>>>default)
>>>>>VSI Virtualization:
>>>>>- The "large file API" (VSI*L) has been re-engineered to allow
>>installing
>>>>> additional file handlers at runtime.
>>>>>- Added "in memory" VSI handler so that now any driver using VSI*L
>>>>> functions for data access can operate on in-memory files.
>>>>>- PNG, JPEG and GeoTIFF drivers upgraded to work with in-memory
support.
>>>>>Raster Attribute Tables:
>>>>>- Implemented new Raster Attribute Tables support. See the
>>>>> GDALRasterAttributeTable class for more information.
>>>>>Erdas Imagine Overviews:
>>>>>- Erdas Imagine driver upgraded to support building internal
overviews.
>>>>>- Generic overview handler updated to support overviews in Erdas
Imagine
>>>>> format for any file format. Set USE_RRD config option to YES to
>>>>enable.
>>>>>gdalwarp:
>>>>>- Added proper support for "unified source nodata", so the -srcnodata
>>>>> switch works well.
>>>>>RIK Driver:
>>>>>- New Swedish format driver implemented by Daniel Wallner.
>>>>>JPEG Driver:
>>>>>- Substantial improvements to EXIF support.
>>>>>MrSID Driver:
>>>>>- Updated with proper JPEG2000 support as JP2MRSID driver, including
>>>>> encoding with ESDK.
>>>>>- Updated to support MrSID Version 5.x SDKs.
>>>>>PNG Driver:
>>>>>- Fixed serious bugs with 16bit file support.
>>>>>- Added NODATA_VALUES to identify RGB sets that indicate a nodata
pixel.
>>>>>OGR 1.3.1 - Overview of Changes
>>>>>Reference Counting:
>>>>>- OGRSpatialReference and OGRFeatureDefn now honour reference counting
>>>>> semantics.
>>>>>- Note that, especially for the OGRFeatureDefn, it is now critical
that
>>>>> all drivers be careful with reference counting. Any OGR drivers not
>>in
>>>>> the core distribution will likely crash if not updated.
>>>>>ESRI Personal Geodatabase Driver:
>>>>>- New driver implemented for ESRI Personal Geodatabase (.mdb) files.
>>>>>- Uses ODBC, enabled by default on win32.
>>>>>ODBC Driver:
>>>>>- Updated to support binary fields.
>>>>>- Updated to support WKB geometry fields.
>>>>>- Updated to support DSN-less connections.
>>>>>S57 Driver:
>>>>>- Added support for Inland Waterways, and Additional Military Layers
>>>>profiles
