GDAL/OGR 1.3.1 Released - Building failed on Windows with
MinGW
david techer
davidtecher at YAHOO.FR
Thu Oct 6 18:53:23 EDT 2005
Ok Tamas thanks you
By VS7 you mean Visual Studio 7?
--david;
Jean David TECHER
e-mail: davidtecher(at)yahoo(dot)fr
site: http://techer.pascal.free.fr/postgis/
Tamas Szekeres a écrit :
>David,
>Without being concerned with MinGW/Msys the library successfully compiles
>on Windows using VS7. The only problem was with the compilation of the
>SWIG C# library that could finally be succeeded with the method described
>in:
>http://bugzilla.remotesensing.org/show_bug.cgi?id=949
>Tamas Szekeres
>On Thu, 6 Oct 2005 21:05:17 +0400, david techer <davidtecher at YAHOO.FR>
>wrote:
>>Tamas is right!
>>I tryed myself to compil it on Windows using MinGW and Msys but without
>any success.
>>BTW, is there someone who can give me the commands he used to compil on
>Windows
>>with MinGW/Msys. There is GDAL FAQ and the mailing-list and I tryed from
>the archive
>>but if someon can just give to me the commands he did...
>>Since I'm used to compiling/building PostgreSQL/PostGIS/Geos/Proj on
>windows, if I do it
>>for gdal it will be a great help...
>>Thanks.
>>Regards.
>>David.
>>--david;
>>Jean David TECHER
>>>Frank,
>>>Thank you for the release. However in order to compile SWIG with C# some
>>>modifications should be made in the makefile and some typemaps should be
>>>added.
>>>Tamas
>>>On Tue, 4 Oct 2005 15:32:51 -0400, Frank Warmerdam <warmerdam at POBOX.COM>
>>>wrote:
>>>>Folks,
>>>>I am pleased to announce the release of GDAL/OGR 1.3.1. This is mostly
>a
>>>>bug fix release, though there are a few new and improved drivers.
>>>>Source:
>>>>http://www.gdal.org/dl/gdal-1.3.1.tar.gz
>>>>http://www.gdal.org/dl/gdal131.zip
>>>>Docs / Web site:
>>>>http://www.gdal.org/dl/gdal131doc.zip
>>>>Test Suite:
>>>>http://www.gdal.org/dl/gdalautotest-1.3.1.tar.gz
>>>>The major news with this release is that the "Next Generation" Perl,
>>>Python
>>>>and Ruby bindings are now considered ready to use, though I'm sure there
>>>will
>>>>be some additional improvements to them in the coming months. I would
>>>like to
>>>>give out a special thank you to Ari Jolma (perl), Charlie Savage (Ruby),
>>>>Kevin Ruland (Python + overall NG work) and Howard Butler who have put
>in
>>>a
>>>>huge amount of effort on these bindings. If we can get champions for
>>>Java,
>>>>C# and PHP that are willing to brave the dark depths of SWIG, I'm sure
>we
>>>can
>>>>make good progress on them too.
>>>>Best regards,
>>>>I set the clouds in motion - turn up | Frank Warmerdam,
>>>warmerdam at pobox.com
>>>>light and sound - activate the windows | http://pobox.com/~warmerdam
>>>>and watch the world go round - Rush | Geospatial Programmer for Rent
>>>>GDAL 1.3.1 - Overview of Changes
>>>>Next Generation SWIG Wrappers (GDAL and OGR):
>>>>- Python, Perl and Ruby bindings considered to be ready to use.
>>>>- C#, Java, PHP are at best initial prototypes.
>>>>- Added configure options for most NG options.
>>>>PCRaster Driver:
>>>>- libcsf is now included as part of GDAL.
>>>>- PCRaster enabled by default on win32.
>>>>- --with-pcraster=internal option now supported on unix (but not yet
>>>default)
>>>>VSI Virtualization:
>>>>- The "large file API" (VSI*L) has been re-engineered to allow
>installing
>>>> additional file handlers at runtime.
>>>>- Added "in memory" VSI handler so that now any driver using VSI*L
>>>> functions for data access can operate on in-memory files.
>>>>- PNG, JPEG and GeoTIFF drivers upgraded to work with in-memory support.
>>>>Raster Attribute Tables:
>>>>- Implemented new Raster Attribute Tables support. See the
>>>> GDALRasterAttributeTable class for more information.
>>>>Erdas Imagine Overviews:
>>>>- Erdas Imagine driver upgraded to support building internal overviews.
>>>>- Generic overview handler updated to support overviews in Erdas Imagine
>>>> format for any file format. Set USE_RRD config option to YES to
>>>enable.
>>>>gdalwarp:
>>>>- Added proper support for "unified source nodata", so the -srcnodata
>>>> switch works well.
>>>>RIK Driver:
>>>>- New Swedish format driver implemented by Daniel Wallner.
>>>>JPEG Driver:
>>>>- Substantial improvements to EXIF support.
>>>>MrSID Driver:
>>>>- Updated with proper JPEG2000 support as JP2MRSID driver, including
>>>> encoding with ESDK.
>>>>- Updated to support MrSID Version 5.x SDKs.
>>>>PNG Driver:
>>>>- Fixed serious bugs with 16bit file support.
>>>>- Added NODATA_VALUES to identify RGB sets that indicate a nodata pixel.
>>>>OGR 1.3.1 - Overview of Changes
>>>>Reference Counting:
>>>>- OGRSpatialReference and OGRFeatureDefn now honour reference counting
>>>> semantics.
>>>>- Note that, especially for the OGRFeatureDefn, it is now critical that
>>>> all drivers be careful with reference counting. Any OGR drivers not
>in
>>>> the core distribution will likely crash if not updated.
>>>>ESRI Personal Geodatabase Driver:
>>>>- New driver implemented for ESRI Personal Geodatabase (.mdb) files.
>>>>- Uses ODBC, enabled by default on win32.
>>>>ODBC Driver:
>>>>- Updated to support binary fields.
>>>>- Updated to support WKB geometry fields.
>>>>- Updated to support DSN-less connections.
>>>>S57 Driver:
>>>>- Added support for Inland Waterways, and Additional Military Layers
>>>profiles
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051007/a7ef2055/attachment.html
