GDV Client
Oliver Wesp
wesp at GDV.COM
Fri Oct 7 03:29:26 EDT 2005
On browser refresh the calculation of the mapsize fails and is submitted
to mapserser as NaN. I have no idea why the files are (most likely)
loaded in a different order on browser refresh so that MapWidth and
MapHeight are not calculateted when the mapserver form is first
submitted. I will look into it and maybe there is a way around this error.
Oliver
Lester Caine schrieb:
> Janice Denovan wrote:
>> Lester and List,
>> I also thought the GDV Client worth exploring. I find:
>> * Easy install (even with my 3 words of German)
>> * Nice use of frames - maximizes the map area
>> * Basic navigations tools - all working
>> My only complaint is that on browser refresh (that's an F5 for IE or
>> Ctrl-R
>> for Mozilla) the application breaks with "getNumeric(): Incorrect data
>> type." The GDV Client demo site at http://www.gdv-
>> gis.de/mapserver/htmlviewer/html/viewer.html fails, Lester's site breaks
>> and my site breaks. Any thoughts ?
> I have moved on a bit
> http://home.lsces.co.uk/bitweaver/mapper/display_map.php
> has it integrated with the bitweaver framework ready for adding
> additional facilities.
> The refresh problem relates to the way the browser loads the last file
> accessed. If you use <Shift><Reload> in Mozilla there is not a problem.
Dipl.-Geogr. Oliver Wesp
Gesellschaft fuer geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
