how the " itemquery mode" works?
Fawcett, David
David.Fawcett at STATE.MN.US
Mon Oct 10 09:26:37 EDT 2005
Marcello,
Radio buttons should work just fine for telling MapServer what mode you want to use. I suggest posting the text of your template file so we can look at it.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Marcello Benigno Borges de Barros Filho
Sent: Sunday, October 09, 2005 7:39 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] how the " itemquery mode" works?
Hi all,
Recently I made some tests with queries in mapserver using the "Beginning Mapserver" book examples , but i have some questions about the "itemquery mode". For example, i tested wiht <SELECT ...> html command and my example works fine:
<select name="mode">
<option value="browse">Browse</option>
<option value="query">query</option>
<option value="itemquery">query by attributes</option>
</select>
When i try the same with radio buttons, the "itemquery mode" doesn´t works.
<input type="radio" name="mode" value="browse" checked>Browse;<br>
<input type="radio" name="mode" value="query" >query<br>
<input type="radio" name="mode" value="itemquery" >query by attributes<br>
The map file and the header and footer files are the same in my two examples. why will be? Some wrong CGI parameter?
Best regards,
Marcello
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051010/558ef230/attachment.html
