Need some help on WMS server.
Paul Turner
pturner at CCALMR.OGI.EDU
Mon Oct 10 14:55:02 EDT 2005
David,
STATUS ON works for me, thx a heap!
--Paul
Paul J Turner
Fawcett, David wrote:
>Paul,
>I am guessing that you are getting the same image every time because you
>have all three layers STATUS set to default. Therefore, however you
>request it, all three layers are drawing and the last one in your map
>file is being drawn on top.
>I would suggest setting the layers STATUS to ON, and then using the
>layers parameter in your GetMap request to select the layer that you are
>interested in.
>David.
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>Behalf Of Paul Turner
>Sent: Monday, October 10, 2005 11:36 AM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] Need some help on WMS server.
>I'm bringing up a WMS server and I'm having problems serving different
>images from the same map file. It looks like only the last image of the
>3 is being served.
>The server is at
>http://www.ccalmr.ogi.edu/cgi-bin/mapserv?map=/usr/local/apache/mapserve
>r/wms.map
>There are 3 images served, one per layer, and each is different (I've
>verified this) but it seems that in every WMS client I use, the same
>image shows up no matter which layer I select (the last image).
>Any suggestions appreciated.
>Thx,
>--Paul
>Paul J Turner
>OHSU-OGI-CCALMR
>mapserver CGI is configured thusly:
>/usr/local/apache/cgi-bin) mapserv -v
>MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>INPUT=SHAPEFILE
>Here is the map file:
>MAP
> NAME "CORIE Dev Forecast"
> DEBUG ON
># SIZE 550 450
># IMAGETYPE GIF
> UNITS DD
> EXTENT -125.300000 45.300000 -122.844754 47.299633
> WEB
> LOG "/tmp/mapserver.log"
> IMAGEPATH "/usr/local/apache/htdocs/ms/tmp"
> IMAGEURL "/ms/tmp/"
> METADATA
> "wms_title" "CORIE WMS Service"
> "wms_onlineresource"
>"http://www.ccalmr.ogi.edu/cgi-bin/mapserv?map=/usr/local/apache/mapserv
>er/wms.map&"
>##required
> "wms_srs" "epsg:4326"
> "wms_format" "image/gif"
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME "devforecast1"
> STATUS DEFAULT
> DUMP TRUE
> METADATA
> "wms_title" "DevForecast 1" ##required
> "gml_include_items" "all"
> END
> TYPE RASTER
> DATA
>"/usr/local/apache/mapserver/llcolsal_plume_surface_000090000.gif"
> PROJECTION
> "init=epsg:4326" ##recommended
> END
> END
> LAYER
> NAME "devforecast2"
> STATUS DEFAULT
> DUMP TRUE
> METADATA
> "wms_title" "DevForecast 2" ##required
> END
> TYPE RASTER
> DATA
>"/usr/local/apache/mapserver/llcolsal_plume_surface_000093600.gif"
> PROJECTION
> END
> END
> LAYER
> NAME "devforecast3"
> STATUS DEFAULT
> DUMP TRUE
> METADATA
> "wms_title" "DevForecast 3" ##required
> END
> TYPE RASTER
> DATA
>"/usr/local/apache/mapserver/llcolsal_plume_surface_000097200.gif"
> PROJECTION
> END
> END
>END
>The images can be seen at (warning, 2048x2048):
>http://www.ccalmr.ogi.edu/ms/llcolsal_plume_surface_000090000.gif
>http://www.ccalmr.ogi.edu/ms/llcolsal_plume_surface_000093600.gif
>http://www.ccalmr.ogi.edu/ms/llcolsal_plume_surface_000097200.gif
