floating point grass rasters and mapserver
William Kyngesburye
woklist at KYNGCHAOS.COM
Tue Oct 11 10:18:06 EDT 2005
I thought I heard that you could use a grass image group in
mapserver. Have 3 bands in the group with 0-255 each for RGB. Never
got around to trying it. Since MapServer doesn't doesn't use the
GRASS color info, I guess it would only work for image-type data
directly, you would have to manually transform something like
elevation data into 3 bands.
On Oct 11, 2005, at 3:23 AM, Jachym Cepicky wrote:
> hi,
> I had that feeling, that mapserver is able to display *only* maps with
> <= 255 values..
> I thing, there is no other way, than to double the maps :-/
> Jachym
> On Tue, Oct 11, 2005 at 09:18:40AM +0200, Andrea Antonello wrote:
>> Hi folks,
>> I trying to visualize grass rasters with mapserver.
>> What I get are nice maps, but those that are floating point and
>> numbers > 255
>> are visualized in one single color, usually yellow, which probably
>> only means
>> that the image is rendered at low resolution level.
>> I read the documentation about rasters more than once, but I seem
>> to miss a
>> point.
>> I use png24.
>> If I normalize the map (i.e. map*maxvalue/255), it shows up
>> correctly, but I
>> don't want to double the maps and also I want to see changes on
>> the grass
>> location.
>> Any hint is appreciated.
>> Best regards,
>> Andrea
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
