floating point grass rasters and mapserver
Andrea Antonello
andrea.antonello at GMAIL.COM
Tue Oct 11 10:46:01 EDT 2005
Frank,
> I would suggest reviewing the Raster howto.
> http://ms.gis.umn.edu/docs/howto/raster_data
Yes, it's from there I'm coming. I don't if it's a language limit, but I
didn't get it exactly. Or worse, I thought I had it, but instead I didn't.
> MapServer supports scaling non-8bit data to 8bit on the fly
> (see the SCALE processing option in the Raster howto) or
> to use classification on non-8bit images.
I tried to use it passing the min and the max, but my result is the yellow
map.
LAYER
NAME bacino.rescaled.100
TYPE RASTER
STATUS DEFAULT
DATA
"/centralgisenvironment/grassdb/liguria/def50m//cellhd/bacino.rescaled.100"
PROCESSING "SCALE=1,229172"
END
where 1 and 229172 are min and max.
Then I tried with PROCESSING "SCALE=AUTO" expecting the same to happen, but in
that case I get a black layer.
What is going on?
Thanks,
Andrea
> Best regards,
>--- I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com light and sound - activate the windows |
> http://pobox.com/~warmerdam and watch the world go round - Rush |
> Geospatial Programmer for Rent
____________________________________________________________________________
HydroloGIS - Environmental Open Source Solutions
www.hydrologis.com
Andrea Antonello
Environmental Engineer
mobile: +393288497722
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
