PROJ Problem
    Avramov,Daniel [Ontario]
    Daniel.Avramov at EC.GC.CA
    Tue Oct 11 08:55:12 PDT 2005
How do we set up an Environment Variable in IIS 6 for the PROJ_LIB?
The reason we are asking is that we are encountering problems with the
projection library not being found.
It is fixed when the the PROJ folder is sitting on the C: drive (Not a
desired solution)
OR
It works when we have the CONFIG PROJ_LIB set in the MapFile (We do not
want to have to do this all this time).
We are using CWC2 which writes out a default.map file without our
specific CONFIG PROJ_LIB statement/path.
How would we write to the map file our CONFIG statement using php/php
mapscript?
Thanks in advance.
Daniel and Debbie.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051011/68851ffa/attachment.htm>
More information about the MapServer-users
