time series problem 2
Jeroen Ticheler
Jeroen.Ticheler at FAO.ORG
Wed Oct 12 03:54:26 EDT 2005
Further to my previous message, the exception I get is the following
one:
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidDimensionValue">
msWMSApplyTime: WMS server error. Time value(s) 2005-09-21 given is
invalid or outside the time extent defined
(2005-03-11,2005-03-21,2005-04-01,2005-04-11,2005-04-21,2005-05-01,2005-
05-11,2005-05-21,2005-06-01,2005-06-11,2005-06-21,2005-07-01,2005-07-11,
2005-07-21,2005-08-01,2005-08-11,2005-08-21,2005-09-01,2005-09-11,2005-0
9-21), and default time set is invalid (2005-09-21)
</ServiceException>
</ServiceExceptionReport>
And the URL's I use are:
For Capabilities:
http://193.43.36.137/cgi-bin/spotveg?
version=1.1.1&service=WMS&request=GetCapabilities
For a working map without specifying the time:
version=1.1.1&service=WMS&request=GetMap&srs=EPSG:
4326&bbox=-180,-90,180,90&format=image/
png&layers=spotndvi&transparent=true&width=400&height=200
For a request with a time, the exception is returned:
png&layers=spotndvi&transparent=true&width=400&height=200&time=2005-09-2
1
These URL's can be reached from outside, so you can try this yourself.
Thanks in advance for any help to a solution,
Jeroen
On 11 Oct 2005, at 19:20, Jeroen Ticheler wrote:
> Hi,
> I have a problem with time series for WMS. I have used the
> following WMS attributes in my map file and I get the default image
> the first WMS map request. The moment I start requesting maps with
> the time variable set, I get an exception indicating that the time
> format used is not correct.
> The data is GeoTIFF
> I have an index shapefile with an imgdate column containing the
> dates in the same format
> Anyone an idea, I can't find an example that has a whole range of
> images with a specific time set for each image.
> Map file extract:
> At the map level (although I don't think this is supported/needed
> for GeoTIFF data!?)
> ____________________________
> "wms_timeformat" "YYYY-MM-DD"
> At the layer level
> "wms_style_default_title" "default"
> "wms_format" "image/png"
> "wms_timedefault" "2005-09-11"
> "wms_timeextent"
> "2005-08-21,2005-09-01,2005-09-11" # also tried with
> spaces after each comma
> "wms_timeitem" "imgdate"
> END
> DUMP TRUE
> TILEINDEX 'ndvi_idx'
> TILEITEM "location"
> EXTENT -180.0 -90.0 180.0 90.0
> PROJECTION "init=epsg:4326" END
> Thanks in advance,
> Jeroen
> Jeroen Ticheler
> FAO-UN
> Tel: +39 06 57056041
> http://www.fao.org/geonetwork
> 12.34327°N 12.34327°E
