MS4W applications
Julien-Samuel Lacroix
jlacroix at DMSOLUTIONS.CA
Wed Oct 12 09:48:05 EDT 2005
Hello,
I will try to help you to sort this out.
First there's MapServer. This the engine under all those applications.
MapServer is a server application that takes your data and create a map
image. To be able to do this, MapServer has a configuration file called
mapfile. To understand the mapfile, you can take the MapServer tutorial:
http://hypnos.cbs.umn.edu/tutorial/
To build more complex applications, MapServer has interface called
MapScript. MapScript is simply the MapServer functionality integrated in
the programming language of your choice. See the doc for more details:
http://mapserver.gis.umn.edu/doc.html
After that, MapLab, Chameleon and GMap are three application using
MapServer and PHP/MapScript.
GMap is an example application using PHP/MapScript. To understand how it
works, you will have to look in the code (gmap75.php) and in the mapfile
(gmap75.map).
MapLab is a software to easily build a MapFile for MapServer. Optionally
you can build an application like GMap using GMapFactory, but this is
limited. See the website for more details:
http://www.maptools.org/maplab/index.phtml
Chameleon is a software to easily build advanced applications using
MapServer and PHP/MapScript. It's a templating system so the use is
simple. You provide it a mapfile and a template and it will give you a
fully functional application. The template is a simple HTML page with
special tags in it. This not really a tool to create a mapfile, but you
can play with dynamic layers, creating and manipulating them. See the
http://chameleon.maptools.org/index.phtml
Thanks
Julien
On 10/12/2005 07:57 AM, Carlos Ruiz wrote:
> Hello, I am Carlos Ruiz Luna, studying at the School
> of Engineers of the Canton of Vaud (EIVD) in
> Switzerland.
> I would like to create a website with isochronous
> charts by using the data bases of TeléAtlas (Shape
> format). I installed the OpenSource software MS4W
> v1.2.2 but I don't know wich application I must
> choose:
> 1) Is Chameleon only a set of scripts that i have to
> added to MapLap application? or this is an application
> who allows me to create layers like Maplab?
> 2) It seems that Gmap is an application similar to an
> application obtained with Maplab (GmapFactory) but I
> don't know how to use my own data base and layers.
> Could you tell me how to create the isochron function
> by my own in PHP Mapscript?
> Thanks in advance for your answers, and best regards.
> Carlos Ruiz Luna
> ______________________________________________
> Renovamos el Correo Yahoo!
> Nuevos servicios, más seguridad
> http://correo.yahoo.es
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
