Query attribute
Matthew Edmondson
matt0177 at GMAIL.COM
Wed Oct 12 11:19:54 EDT 2005
When using a OGR Virtual File (often extension .ovf) file to connect to a
database, you can insert a SQL query and only pull certain data. I'm
currently using a similar set up using a MySQL database.
OGR Virtual Files are documented at:
http://www.gdal.org/ogr/drv_vrt.html
Good Luck,
Matt
On 10/12/05, Johan Hallgren <johan.e.hallgren at wmdata.se> wrote:
> Hello
> I have tried to find a way to query attribute in mapserver/mapscript. I
> have found the function queryByAttributes(). I miss some functions here.
> Is there ways to do regular "SELECT fld FROM tbl WHERE id = xy" with
> MapServer?
> Similar question, is queries with LIKE and IN is supported?
> I have found out that it's possible to use regular expression but only on
> shapefiles. What is possible if data is stored in a database?
> Is there some documentation that I have missed, where can it be found?
> Any assistance is welcome.
> Regards
> Johan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051012/0583dbb2/attachment.html
