google maps projection
Ed McNierney
ed at TOPOZONE.COM
Wed Oct 12 16:17:39 EDT 2005
John -
All you have to do is make all your polygons appear to be the wrong
size. And get rid of the scalebars, of course; you can replace them
with rhumb lines for all the compass navigators out there <g>.
I'd suggest the following...
proj=merc
lat_ts=0.0
lon_0=-90.0
x_0=0.0
y_0=0.0
ellps=GRS80
units=m
no_defs
Although I haven't tested that projection myself, as I still prefer
Brazil to look larger than Greenland. The uncommon "lat_ts" parameter
is the latitude of "true scale" - i.e. the only spot on the map that's
accurate...
For more details check the PROJ page at
http://www.remotesensing.org/geotiff/proj_list/mercator_1sp.html but
that should get you off to a good start.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of John Hagstrand
Sent: Wednesday, October 12, 2005 2:25 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] google maps projection
Hello,
I am using MapServer to generate maps that I then overlay on top of
Google Maps. To get them to match up, I need to get the projections to
match.
I've been told the following:
Google Maps uses the Mercator projection and the WGS 84 geodetic datum.
The projection standard latitude is 0, and the projection standard
longitude is -90.
How can I translate that to a MapServer Projection block?
Thanks
John
___________________
John Hagstrand
www.MapTeam.com
847 838 5371
