google maps projection
Chip Taylor
work at XWB.COM
Wed Oct 12 16:28:40 EDT 2005
Ok, you have piqued my interest! Had to go out and look at Google's map
API. Way cool stuff. Anyway, how do you overlay a Mapserver map on top of
a Google map?
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of John Hagstrand
> Sent: Wednesday, October 12, 2005 11:25 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] google maps projection
> Hello,
> I am using MapServer to generate maps that I then overlay on top of Google
> Maps. To get them to match up, I need to get the projections to match.
> I've been told the following:
> Google Maps uses the Mercator projection and the WGS 84 geodetic datum.
> The
> projection standard latitude is 0, and the projection standard longitude
> is
> -90.
> How can I translate that to a MapServer Projection block?
> Thanks
> John
> ___________________
> John Hagstrand
> www.MapTeam.com
> 847 838 5371
