time series problem 3 (Bug!?)
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Oct 13 14:03:38 EDT 2005
Hi There,
Sorry for the late answer.
From what I can see in your examples, you are running into a
limitation of mapserver and it's support for the time extent values.
Currently the time extent can only be defined as a range value and only
one range value is valid (so something like is the only thing valid
2005-09-11/2005-09-21)
You should update your "wms_timeextent" and try it with only one
range. I will enter documentation bug so that this limitation is clearly
defined. Give it a try and let me know.
Later,
Jeroen Ticheler wrote:
> Hi, sorry for continuing this story, but I really want to solve this
> and hope my additional info helps to sort out the problems I face.
> I am using a shapefile with the imgdate column added to it. I use
> exactly the same index to work with a WCS on the same data, that one
> works perfectly fine.
> I have browsed through the mapServer sourcecode to see if I could
> discover something/ understand the problem better. I'm not familiar
> with C coding, so forgive my ignorance :-) What I could understand is
> that my request fails when the time string submitted in the request is
> compared to the timeextent given in the capabilities document.
> The exact section of the code is in between line 545 and line 569,
> apparently the msValidateTimeValue() procedure fails to find the
> requested date in the extent. I do not get an error when I change my
> extent to a range like "2005-09-11,2005-09-21/2005-09-21" or
> "2005-09-11,2005-09-11/2005-09-21", but it will only render the very
> last image, even when an earlier one is requested.
> So I guess I face a bug!?
> Thanks again,
> Jeroen
> Begin forwarded message:
>> From: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>> Date: 12 October 2005 09:54:26 GMT+02:00
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: [UMN_MAPSERVER-USERS] time series problem 2
>> Reply-To: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>> Further to my previous message, the exception I get is the following
>> one:
>> <ServiceExceptionReport version="1.1.1">
>> <ServiceException code="InvalidDimensionValue">
>> msWMSApplyTime: WMS server error. Time value(s) 2005-09-21 given is
>> invalid or outside the time extent defined
>> (2005-03-11,2005-03-21,2005-04-01,2005-04-11,2005-04-21,2005-05-01,200
>> 5-05-11,2005-05-21,2005-06-01,2005-06-11,2005-06-21,2005-07-01,2005-07
>> -11,2005-07-21,2005-08-01,2005-08-11,2005-08-21,2005-09-01,2005-09-11,
>> 2005-09-21), and default time set is invalid (2005-09-21)
>> </ServiceException>
>> </ServiceExceptionReport>
>> And the URL's I use are:
>> For Capabilities:
>> http://193.43.36.137/cgi-bin/spotveg?
>> version=1.1.1&service=WMS&request=GetCapabilities
>> For a working map without specifying the time:
>> version=1.1.1&service=WMS&request=GetMap&srs=EPSG:
>> 4326&bbox=-180,-90,180,90&format=image/
>> png&layers=spotndvi&transparent=true&width=400&height=200
>> For a request with a time, the exception is returned:
>> png&layers=spotndvi&transparent=true&width=400&height=200&time=2005-09
>> -21
>> These URL's can be reached from outside, so you can try this yourself.
>> Thanks in advance for any help to a solution,
>> Jeroen
>> On 11 Oct 2005, at 19:20, Jeroen Ticheler wrote:
>>> Hi,
>>> I have a problem with time series for WMS. I have used the following
>>> WMS attributes in my map file and I get the default image the first
>>> WMS map request. The moment I start requesting maps with the time
>>> variable set, I get an exception indicating that the time format
>>> used is not correct.
>>> The data is GeoTIFF
>>> I have an index shapefile with an imgdate column containing the
>>> dates in the same format
>>> Anyone an idea, I can't find an example that has a whole range of
>>> images with a specific time set for each image.
>>> Map file extract:
>>> At the map level (although I don't think this is supported/needed
>>> for GeoTIFF data!?)
>>> ____________________________
>>> "wms_timeformat" "YYYY-MM-DD"
>>> At the layer level
>>> "wms_style_default_title" "default"
>>> "wms_format" "image/png"
>>> "wms_timedefault" "2005-09-11"
>>> "wms_timeextent"
>>> "2005-08-21,2005-09-01,2005-09-11" # also tried with spaces
>>> after each comma
>>> "wms_timeitem" "imgdate"
>>> END
>>> DUMP TRUE
>>> TILEINDEX 'ndvi_idx'
>>> TILEITEM "location"
>>> EXTENT -180.0 -90.0 180.0 90.0
>>> PROJECTION "init=epsg:4326" END
>>> Thanks in advance,
>>> Jeroen
>>> Jeroen Ticheler
>>> FAO-UN
>>> Tel: +39 06 57056041
>>> http://www.fao.org/geonetwork
>>> 12.34327°N 12.34327°E
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
