data export tool
Martin Tomko
m.tomko at PGRAD.UNIMELB.EDU.AU
Thu Oct 13 20:44:24 EDT 2005
Thank you Frank (I was hoping for your reply, seems like you are always
the person to ask things like this :))
I need to create my dataset (fast vectorization), and I am ready to
chose whatever format is best to do this as fast as possible. I need a
topology top test with my functional programming environment, but
because I am NOT a full strength programmer, compiling c++ stuff and so
one sounds more like a nightmare to me :)
A bit of scripting or SQL is ok :). So, you reckon that ArcINFO binary
vectors would be best? ok, I will give it a try! Oh, I thing we should
have such an extraction function in OGR by default!! (at least for the
poor scientists trying to tune up algorithms :)
Thanks
Martin
Ing. Martin Tomko
PhD. candidate
CRC for Spatial Information
Department of Geomatics
University of Melbourne
Victoria 3010
Australia
phone +61 3 8344 9179
fax +61 3 9349 5185
email m.tomko at pgrad.unimelb.edu.au
url http://www.geom.unimelb.edu.au/tomko
url http://www.spatialinformationscience.org
url http://www.crcsi.com.au
Frank Warmerdam wrote:
> On 10/13/05, Martin Tomko <m.tomko at pgrad.unimelb.edu.au> wrote:
>>I am desperately seeking a tool/workflow o export vector data into
>>text/tables with basically the arc/node topological description of my data.
>>So If I export polygons, I need a table with the polygon IS and the IDs
>>of all its arcs, without any coordinates. Does anyone know a way?
>>I was thinking about postgress/postgis? Dump a shp in it and try an sql?
>>Would ogr2ogr do it somehow? I did not find a way to include the IDs of
>>the arcs of a polygon. Seems like export to CSV would help, but I need
>>to get the arcs IDs somehow.
> Martin,
> You didn't mention what data you are starting with. Is it a shapefile?
> If so, part of your problems is that you need to build the topology from
> a non-topological structure. As Flavio mentioned, FME would be a
> good choice for that. GRASS also has support for converting
> non-topological dataset to topological.
> If you are already starting with a topological Arc/Info binary vector
> coverage, then you will see from the ogrinfo reports that the topology
> information is available as attributes.
> OGRFeature(PAL):2
> ArcIds (IntegerList) = (1:-349)
> AREA (Real) = 0.92814
> PERIMETER (Real) = 5.35872
> COUNTRYD# (Integer) = 2
> COUNTRYD-ID (Integer) = 3027
> POLYGON ((-153.022781372070312 57.383213043212891,...
> OGRFeature(ARC):1
> UserId (Integer) = 1394
> FNODE# (Integer) = 1
> TNODE# (Integer) = 2
> LPOLY# (Integer) = 24
> RPOLY# (Integer) = 26
> LINESTRING (56.360397338867188 25.983451843261719,...
> The ArcIds on the polygons and the node/poly information on the
> arcs is enough to establish the topological relationships. With a
> script or C++ program written on OGR you could get that information
> out into a text format of some kind.
> If you use GRASS to export to E00 you could use avcimport to
> convert to a binary coverage for use with OGR. FME can write
> binary coverages directly. Of course, both FME and GRASS offer
> other mechanisms to interact with the topology that might be more
> direct.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
