time series problem 3 (Bug!?)
Jeroen Ticheler
Jeroen.Ticheler at FAO.ORG
Sat Oct 15 15:53:40 EDT 2005
Thanks! At least I now know I didn't just do things wrong and
understand why some things worked and others not. From the website
this is not at all clear as it gives the impression time series as in
point 2 can be served...
It would be really great if option 2 is supported. Very much in line
with what Jeff wrote, I foresee problems with our map client as well
as with others when I start specifying the time series following
option 4, although it would be an elegant way of describing the time
series :-) Option 2 will be excellent for many of our temporal data
series.
I'll be happy to test, but have to add that I'm traveling in the
coming two weeks, so its hard to reply directly.
Looking forward to a solution!
On one more note: I noted the way time series in WMS and WCS are
defined is different (according to the samples I used). WCS uses an
index file that is added as a separate LAYER, while WMS can directly
use the index shape file. I'm not sure (yet) a WCS time series can be
defined in the same way a WMS can be, but it might be once solution 2
works for WMS!? Otherwise, would there be a way to hide a LAYER
completely from a WMS so one map file can be used for both WCS and WMS?
If my description is not clear, I can post a more detailed
explanation later when back in the office.
Thanks very much in advance!
Jeroen
On 14 Oct 2005, at 04:43, Yewondwossen Assefa wrote:
> Luis W. Sevilla wrote:
>> Hi,
>>> From the specs (wms 1.1 annex c c.3), the extent could be defined
>>> in 4 ways :
>>> 1) value : A single value. This is not directly supported in
>>> Mapserver but there is an easy workwound by specifying the same
>>> value as min and max
>>> 2) value1,value2,value3,... a A list of multiple values. This
>>> is not supported in Mapserver.
>>> 3) min/max/resolution An interval defined by its lower and upper
>>> bounds and its resolution. This is supported in Mapserver
>>> (Note that the resolution is not supported)
>> It sounds quite strange: how do you specify the ammount of time-
>> slices, without giving the resolution?
> You can specify the resolutions in your setting of the
> wms_timeextent parameter. It should be dumped as is in the
> capabilities document. It just won't be used when validating the
> time value passed in the request to see if the value fits in the
> time extents defined. The validation will only use the min max values.
>>> 4) min1/max1/res1,min2/max2/res2,... a A list of multiple
>>> intervals. Not supported
>>> I am willing to add the support for number 4) if you are willing
>>> to do additional testing.
>> We may do some testing too. we're on the way of developping a new
>> WMS cliente with time parameter support, and also interested in
>> publising multitemporal data on the same way.
> I have entred a bug on this issue so discussions/testing can be
> done through this bug.
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1498
>>> I am not sure if 2) is is a must have at this point.
>>> Le me know what you think and then we can proceed with the
>>> impentation.
>>> Later,
>>> Jeroen Ticheler wrote:
>>>> Thanks for that! Is it a complex thing to add such support? I
>>>> had the impression from the code that it was virtually there
>>>> already, just that it first checked for a range and does not
>>>> proceed to check for ranges?
>>>> The problem is that a range doesn't work for this series. Data
>>>> comes in at three 10 daily periods a month, which is not
>>>> exactly true as a month does not always have 30 days. Still the
>>>> images are always dated with a 01, 11 and 21 for the day (or
>>>> 1,2 or 3 for a dekad).
>>>> Ciao,
>>>> Jeroen
>>>> _______________________
>>>> Jeroen Ticheler
>>>> FAO-UN
>>>> Tel: +39 06 57056041
>>>> http://www.fao.org/geonetwork
>>>> 42.07436°N 12.34327°E
>>>> On 13 Oct 2005, at 20:03, Yewondwossen Assefa wrote:
>>>>> Hi There,
>>>>> Sorry for the late answer.
>>>>> From what I can see in your examples, you are running into a
>>>>> limitation of mapserver and it's support for the time extent
>>>>> values. Currently the time extent can only be defined as a
>>>>> range value and only one range value is valid (so something
>>>>> like is the only thing valid 2005-09-11/2005-09-21)
>>>>> You should update your "wms_timeextent" and try it with only
>>>>> one range. I will enter documentation bug so that this
>>>>> limitation is clearly defined. Give it a try and let me know.
>>>>> Later,
>>>>>> Hi, sorry for continuing this story, but I really want to
>>>>>> solve this and hope my additional info helps to sort out the
>>>>>> problems I face.
>>>>>> I am using a shapefile with the imgdate column added to it. I
>>>>>> use exactly the same index to work with a WCS on the same
>>>>>> data, that one works perfectly fine.
>>>>>> I have browsed through the mapServer sourcecode to see if I
>>>>>> could discover something/ understand the problem better. I'm
>>>>>> not familiar with C coding, so forgive my ignorance :-) What
>>>>>> I could understand is that my request fails when the time
>>>>>> string submitted in the request is compared to the
>>>>>> timeextent given in the capabilities document.
>>>>>> The exact section of the code is in between line 545 and
>>>>>> line 569, apparently the msValidateTimeValue() procedure
>>>>>> fails to find the requested date in the extent. I do not get
>>>>>> an error when I change my extent to a range like
>>>>>> "2005-09-11,2005-09-21/2005-09-21" or
>>>>>> "2005-09-11,2005-09-11/2005-09-21", but it will only render
>>>>>> the very last image, even when an earlier one is requested.
>>>>>> So I guess I face a bug!?
>>>>>> Thanks again,
>>>>>> Jeroen
>>>>>> Begin forwarded message:
>>>>>>> From: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>>>>>>> Date: 12 October 2005 09:54:26 GMT+02:00
>>>>>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>>>>> Subject: [UMN_MAPSERVER-USERS] time series problem 2
>>>>>>> Reply-To: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>>>>>>> Further to my previous message, the exception I get is the
>>>>>>> following one:
>>>>>>> <ServiceExceptionReport version="1.1.1">
>>>>>>> <ServiceException code="InvalidDimensionValue">
>>>>>>> msWMSApplyTime: WMS server error. Time value(s) 2005-09-21
>>>>>>> given is invalid or outside the time extent defined
>>>>>>> (2005-03-11,2005-03-21,2005-04-01,2005-04-11,2005-04-21,2005-05-
>>>>>>> 01,2 00
>>>>>>> 5-05-11,2005-05-21,2005-06-01,2005-06-11,2005-06-21,2005-07-01,2
>>>>>>> 005- 07
>>>>>>> -11,2005-07-21,2005-08-01,2005-08-11,2005-08-21,2005-09-01,2005-
>>>>>>> 09-1 1, 2005-09-21), and default time set is invalid
>>>>>>> (2005-09-21)
>>>>>>> </ServiceException>
>>>>>>> </ServiceExceptionReport>
>>>>>>> And the URL's I use are:
>>>>>>> For Capabilities:
>>>>>>> http://193.43.36.137/cgi-bin/spotveg?
>>>>>>> version=1.1.1&service=WMS&request=GetCapabilities
>>>>>>> For a working map without specifying the time:
>>>>>>> version=1.1.1&service=WMS&request=GetMap&srs=EPSG:
>>>>>>> 4326&bbox=-180,-90,180,90&format=image/
>>>>>>> png&layers=spotndvi&transparent=true&width=400&height=200
>>>>>>> For a request with a time, the exception is returned:
>>>>>>> png&layers=spotndvi&transparent=true&width=400&height=200&time=2
>>>>>>> 005- 09 -21
>>>>>>> These URL's can be reached from outside, so you can try this
>>>>>>> yourself.
>>>>>>> Thanks in advance for any help to a solution,
>>>>>>> Jeroen
>>>>>>> On 11 Oct 2005, at 19:20, Jeroen Ticheler wrote:
>>>>>>>> Hi,
>>>>>>>> I have a problem with time series for WMS. I have used the
>>>>>>>> following WMS attributes in my map file and I get the
>>>>>>>> default image the first WMS map request. The moment I
>>>>>>>> start requesting maps with the time variable set, I get an
>>>>>>>> exception indicating that the time format used is not
>>>>>>>> correct.
>>>>>>>> The data is GeoTIFF
>>>>>>>> I have an index shapefile with an imgdate column containing
>>>>>>>> the dates in the same format
>>>>>>>> Anyone an idea, I can't find an example that has a whole
>>>>>>>> range of images with a specific time set for each image.
>>>>>>>> Map file extract:
>>>>>>>> At the map level (although I don't think this is supported/
>>>>>>>> needed for GeoTIFF data!?)
>>>>>>>> ____________________________
>>>>>>>> "wms_timeformat" "YYYY-MM-DD"
>>>>>>>> At the layer level
>>>>>>>> "wms_style_default_title" "default"
>>>>>>>> "wms_format" "image/png"
>>>>>>>> "wms_timedefault" "2005-09-11"
>>>>>>>> "wms_timeextent"
>>>>>>>> "2005-08-21,2005-09-01,2005-09-11" # also tried
>>>>>>>> with spaces after each comma
>>>>>>>> "wms_timeitem" "imgdate"
>>>>>>>> END
>>>>>>>> DUMP TRUE
>>>>>>>> TILEINDEX 'ndvi_idx'
>>>>>>>> TILEITEM "location"
>>>>>>>> EXTENT -180.0 -90.0 180.0 90.0
>>>>>>>> PROJECTION "init=epsg:4326" END
>>>>>>>> Thanks in advance,
>>>>>>>> Jeroen
>>>>>>>> Jeroen Ticheler
>>>>>>>> FAO-UN
>>>>>>>> 12.34327°N 12.34327°E
>>>>> Assefa Yewondwossen
>>>>> Software Analyst
>>>>> Email: assefa at dmsolutions.ca
>>>>> http://www.dmsolutions.ca/
>>>>> Phone: (613) 565-5056 (ext 14)
>>>>> Fax: (613) 565-0925
>> gvSIG development Team
>> www.gvsig.gva.es
> Assefa Yewondwossen
> Software Analyst
> Fax: (613) 565-0925
