time series problem 3 (Bug!?)
Jeroen Ticheler
Jeroen.Ticheler at FAO.ORG
Mon Oct 24 16:23:59 EDT 2005
Hi!
I was wondering if anything was decided on the WMS/WCS time series
support options?
Thanks in advance,
Jeroen
On 15 Oct 2005, at 21:53, Jeroen Ticheler wrote:
> Thanks! At least I now know I didn't just do things wrong and
> understand why some things worked and others not. From the website
> this is not at all clear as it gives the impression time series as
> in point 2 can be served...
> It would be really great if option 2 is supported. Very much in
> line with what Jeff wrote, I foresee problems with our map client
> as well as with others when I start specifying the time series
> following option 4, although it would be an elegant way of
> describing the time series :-) Option 2 will be excellent for many
> of our temporal data series.
> I'll be happy to test, but have to add that I'm traveling in the
> coming two weeks, so its hard to reply directly.
> Looking forward to a solution!
> On one more note: I noted the way time series in WMS and WCS are
> defined is different (according to the samples I used). WCS uses an
> index file that is added as a separate LAYER, while WMS can
> directly use the index shape file. I'm not sure (yet) a WCS time
> series can be defined in the same way a WMS can be, but it might be
> once solution 2 works for WMS!? Otherwise, would there be a way to
> hide a LAYER completely from a WMS so one map file can be used for
> both WCS and WMS?
> If my description is not clear, I can post a more detailed
> explanation later when back in the office.
> Thanks very much in advance!
> Jeroen
> On 14 Oct 2005, at 04:43, Yewondwossen Assefa wrote:
>> Luis W. Sevilla wrote:
>>> Hi,
>>>> From the specs (wms 1.1 annex c c.3), the extent could be
>>>> defined in 4 ways :
>>>> 1) value : A single value. This is not directly supported in
>>>> Mapserver but there is an easy workwound by specifying the same
>>>> value as min and max
>>>> 2) value1,value2,value3,... a A list of multiple values. This
>>>> is not supported in Mapserver.
>>>> 3) min/max/resolution An interval defined by its lower and upper
>>>> bounds and its resolution. This is supported in Mapserver
>>>> (Note that the resolution is not supported)
>>> It sounds quite strange: how do you specify the ammount of time-
>>> slices, without giving the resolution?
>> You can specify the resolutions in your setting of the
>> wms_timeextent parameter. It should be dumped as is in the
>> capabilities document. It just won't be used when validating the
>> time value passed in the request to see if the value fits in the
>> time extents defined. The validation will only use the min max
>> values.
>>>> 4) min1/max1/res1,min2/max2/res2,... a A list of multiple
>>>> intervals. Not supported
>>>> I am willing to add the support for number 4) if you are
>>>> willing to do additional testing.
>>> We may do some testing too. we're on the way of developping a new
>>> WMS cliente with time parameter support, and also interested in
>>> publising multitemporal data on the same way.
>> I have entred a bug on this issue so discussions/testing can be
>> done through this bug.
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1498
>>>> I am not sure if 2) is is a must have at this point.
>>>> Le me know what you think and then we can proceed with the
>>>> impentation.
>>>> Later,
>>>>> Thanks for that! Is it a complex thing to add such support? I
>>>>> had the impression from the code that it was virtually there
>>>>> already, just that it first checked for a range and does not
>>>>> proceed to check for ranges?
>>>>> The problem is that a range doesn't work for this series. Data
>>>>> comes in at three 10 daily periods a month, which is not
>>>>> exactly true as a month does not always have 30 days. Still
>>>>> the images are always dated with a 01, 11 and 21 for the day
>>>>> (or 1,2 or 3 for a dekad).
>>>>> Ciao,
>>>>> Jeroen
>>>>> _______________________
>>>>> Jeroen Ticheler
>>>>> FAO-UN
>>>>> Tel: +39 06 57056041
>>>>> http://www.fao.org/geonetwork
>>>>> 42.07436°N 12.34327°E
>>>>> On 13 Oct 2005, at 20:03, Yewondwossen Assefa wrote:
>>>>>> Hi There,
>>>>>> Sorry for the late answer.
>>>>>> From what I can see in your examples, you are running into a
>>>>>> limitation of mapserver and it's support for the time extent
>>>>>> values. Currently the time extent can only be defined as a
>>>>>> range value and only one range value is valid (so something
>>>>>> like is the only thing valid 2005-09-11/2005-09-21)
>>>>>> You should update your "wms_timeextent" and try it with only
>>>>>> one range. I will enter documentation bug so that this
>>>>>> limitation is clearly defined. Give it a try and let me know.
>>>>>> Later,
>>>>>>> Hi, sorry for continuing this story, but I really want to
>>>>>>> solve this and hope my additional info helps to sort out
>>>>>>> the problems I face.
>>>>>>> I am using a shapefile with the imgdate column added to it. I
>>>>>>> use exactly the same index to work with a WCS on the same
>>>>>>> data, that one works perfectly fine.
>>>>>>> I have browsed through the mapServer sourcecode to see if I
>>>>>>> could discover something/ understand the problem better.
>>>>>>> I'm not familiar with C coding, so forgive my ignorance :-)
>>>>>>> What I could understand is that my request fails when the
>>>>>>> time string submitted in the request is compared to the
>>>>>>> timeextent given in the capabilities document.
>>>>>>> The exact section of the code is in between line 545 and
>>>>>>> line 569, apparently the msValidateTimeValue() procedure
>>>>>>> fails to find the requested date in the extent. I do not
>>>>>>> get an error when I change my extent to a range like
>>>>>>> "2005-09-11,2005-09-21/2005-09-21" or
>>>>>>> "2005-09-11,2005-09-11/2005-09-21", but it will only render
>>>>>>> the very last image, even when an earlier one is requested.
>>>>>>> So I guess I face a bug!?
>>>>>>> Thanks again,
>>>>>>> Jeroen
>>>>>>> Begin forwarded message:
>>>>>>>> From: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>>>>>>>> Date: 12 October 2005 09:54:26 GMT+02:00
>>>>>>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>>>>>> Subject: [UMN_MAPSERVER-USERS] time series problem 2
>>>>>>>> Reply-To: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>>>>>>>> Further to my previous message, the exception I get is the
>>>>>>>> following one:
>>>>>>>> <ServiceExceptionReport version="1.1.1">
>>>>>>>> <ServiceException code="InvalidDimensionValue">
>>>>>>>> msWMSApplyTime: WMS server error. Time value(s) 2005-09-21
>>>>>>>> given is invalid or outside the time extent defined
>>>>>>>> (2005-03-11,2005-03-21,2005-04-01,2005-04-11,2005-04-21,2005-05
>>>>>>>> -01,2 00
>>>>>>>> 5-05-11,2005-05-21,2005-06-01,2005-06-11,2005-06-21,2005-07-01,
>>>>>>>> 2005- 07
>>>>>>>> -11,2005-07-21,2005-08-01,2005-08-11,2005-08-21,2005-09-01,2005
>>>>>>>> -09-1 1, 2005-09-21), and default time set is invalid
>>>>>>>> (2005-09-21)
>>>>>>>> </ServiceException>
>>>>>>>> </ServiceExceptionReport>
>>>>>>>> And the URL's I use are:
>>>>>>>> For Capabilities:
>>>>>>>> http://193.43.36.137/cgi-bin/spotveg?
>>>>>>>> version=1.1.1&service=WMS&request=GetCapabilities
>>>>>>>> For a working map without specifying the time:
>>>>>>>> version=1.1.1&service=WMS&request=GetMap&srs=EPSG:
>>>>>>>> 4326&bbox=-180,-90,180,90&format=image/
>>>>>>>> png&layers=spotndvi&transparent=true&width=400&height=200
>>>>>>>> For a request with a time, the exception is returned:
>>>>>>>> png&layers=spotndvi&transparent=true&width=400&height=200&time=
>>>>>>>> 2005- 09 -21
>>>>>>>> These URL's can be reached from outside, so you can try
>>>>>>>> this yourself.
>>>>>>>> Thanks in advance for any help to a solution,
>>>>>>>> Jeroen
>>>>>>>> On 11 Oct 2005, at 19:20, Jeroen Ticheler wrote:
>>>>>>>>> Hi,
>>>>>>>>> I have a problem with time series for WMS. I have used
>>>>>>>>> the following WMS attributes in my map file and I get the
>>>>>>>>> default image the first WMS map request. The moment I
>>>>>>>>> start requesting maps with the time variable set, I get
>>>>>>>>> an exception indicating that the time format used is not
>>>>>>>>> correct.
>>>>>>>>> The data is GeoTIFF
>>>>>>>>> I have an index shapefile with an imgdate column containing
>>>>>>>>> the dates in the same format
>>>>>>>>> Anyone an idea, I can't find an example that has a whole
>>>>>>>>> range of images with a specific time set for each image.
>>>>>>>>> Map file extract:
>>>>>>>>> At the map level (although I don't think this is supported/
>>>>>>>>> needed for GeoTIFF data!?)
>>>>>>>>> ____________________________
>>>>>>>>> "wms_timeformat" "YYYY-MM-DD"
>>>>>>>>> At the layer level
>>>>>>>>> "wms_style_default_title" "default"
>>>>>>>>> "wms_format" "image/png"
>>>>>>>>> "wms_timedefault" "2005-09-11"
>>>>>>>>> "wms_timeextent"
>>>>>>>>> "2005-08-21,2005-09-01,2005-09-11" # also tried
>>>>>>>>> with spaces after each comma
>>>>>>>>> "wms_timeitem" "imgdate"
>>>>>>>>> END
>>>>>>>>> DUMP TRUE
>>>>>>>>> TILEINDEX 'ndvi_idx'
>>>>>>>>> TILEITEM "location"
>>>>>>>>> EXTENT -180.0 -90.0 180.0 90.0
>>>>>>>>> PROJECTION "init=epsg:4326" END
>>>>>>>>> Thanks in advance,
>>>>>>>>> Jeroen
>>>>>>>>> Jeroen Ticheler
>>>>>>>>> FAO-UN
>>>>>>>>> 12.34327°N 12.34327°E
>>>>>> Assefa Yewondwossen
>>>>>> Software Analyst
>>>>>> Email: assefa at dmsolutions.ca
>>>>>> http://www.dmsolutions.ca/
>>>>>> Phone: (613) 565-5056 (ext 14)
>>>>>> Fax: (613) 565-0925
>>> gvSIG development Team
>>> www.gvsig.gva.es
>> Assefa Yewondwossen
>> Software Analyst
>> Fax: (613) 565-0925
