time series problem 3 (Bug!?)
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Oct 25 12:09:24 EDT 2005
Jeroen Ticheler wrote:
> Hi!
> I was wondering if anything was decided on the WMS/WCS time series
> support options?
> Thanks in advance,
> Jeroen
> On 15 Oct 2005, at 21:53, Jeroen Ticheler wrote:
>> Thanks! At least I now know I didn't just do things wrong and
>> understand why some things worked and others not. From the website
>> this is not at all clear as it gives the impression time series as in
>> point 2 can be served...
>> It would be really great if option 2 is supported. Very much in line
>> with what Jeff wrote, I foresee problems with our map client as well
>> as with others when I start specifying the time series following
>> option 4, although it would be an elegant way of describing the time
>> series :-) Option 2 will be excellent for many of our temporal data
>> series.
>> I'll be happy to test, but have to add that I'm traveling in the
>> coming two weeks, so its hard to reply directly.
>> Looking forward to a solution!
I have added the support for diffrent types of time extents (Option 2
and 4). It is described in bug 1498
(http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1498).
I have done initila testst and will still continue to do a bit of
testsing. I would appreciate if you update the bug after you tested it
with your own data.
>> On one more note: I noted the way time series in WMS and WCS are
>> defined is different (according to the samples I used). WCS uses an
>> index file that is added as a separate LAYER, while WMS can directly
>> use the index shape file. I'm not sure (yet) a WCS time series can be
>> defined in the same way a WMS can be, but it might be once solution 2
>> works for WMS!? Otherwise, would there be a way to hide a LAYER
>> completely from a WMS so one map file can be used for both WCS and WMS?
>> If my description is not clear, I can post a more detailed
>> explanation later when back in the office.
I guess a new thread and more details would be welcome.
>> Thanks very much in advance!
>> Jeroen
>> On 14 Oct 2005, at 04:43, Yewondwossen Assefa wrote:
>>> Luis W. Sevilla wrote:
>>>> Hi,
>>>>> From the specs (wms 1.1 annex c c.3), the extent could be defined
>>>>> in 4 ways :
>>>>> 1) value : A single value. This is not directly supported in
>>>>> Mapserver but there is an easy workwound by specifying the same
>>>>> value as min and max
>>>>> 2) value1,value2,value3,... a A list of multiple values. This
>>>>> is not supported in Mapserver.
>>>>> 3) min/max/resolution An interval defined by its lower and upper
>>>>> bounds and its resolution. This is supported in Mapserver
>>>>> (Note that the resolution is not supported)
>>>> It sounds quite strange: how do you specify the ammount of time-
>>>> slices, without giving the resolution?
>>> You can specify the resolutions in your setting of the
>>> wms_timeextent parameter. It should be dumped as is in the
>>> capabilities document. It just won't be used when validating the
>>> time value passed in the request to see if the value fits in the
>>> time extents defined. The validation will only use the min max values.
>>>>> 4) min1/max1/res1,min2/max2/res2,... a A list of multiple
>>>>> intervals. Not supported
>>>>> I am willing to add the support for number 4) if you are willing
>>>>> to do additional testing.
>>>> We may do some testing too. we're on the way of developping a new
>>>> WMS cliente with time parameter support, and also interested in
>>>> publising multitemporal data on the same way.
>>> I have entred a bug on this issue so discussions/testing can be done
>>> through this bug.
>>>>> I am not sure if 2) is is a must have at this point.
>>>>> Le me know what you think and then we can proceed with the
>>>>> impentation.
>>>>> Later,
>>>>>> Thanks for that! Is it a complex thing to add such support? I had
>>>>>> the impression from the code that it was virtually there
>>>>>> already, just that it first checked for a range and does not
>>>>>> proceed to check for ranges?
>>>>>> The problem is that a range doesn't work for this series. Data
>>>>>> comes in at three 10 daily periods a month, which is not exactly
>>>>>> true as a month does not always have 30 days. Still the images
>>>>>> are always dated with a 01, 11 and 21 for the day (or 1,2 or 3
>>>>>> for a dekad).
>>>>>> Ciao,
>>>>>> Jeroen
>>>>>> _______________________
>>>>>> Jeroen Ticheler
>>>>>> FAO-UN
>>>>>> Tel: +39 06 57056041
>>>>>> http://www.fao.org/geonetwork
>>>>>> 42.07436°N 12.34327°E
>>>>>> On 13 Oct 2005, at 20:03, Yewondwossen Assefa wrote:
>>>>>>> Hi There,
>>>>>>> Sorry for the late answer.
>>>>>>> From what I can see in your examples, you are running into a
>>>>>>> limitation of mapserver and it's support for the time extent
>>>>>>> values. Currently the time extent can only be defined as a
>>>>>>> range value and only one range value is valid (so something
>>>>>>> like is the only thing valid 2005-09-11/2005-09-21)
>>>>>>> You should update your "wms_timeextent" and try it with only
>>>>>>> one range. I will enter documentation bug so that this
>>>>>>> limitation is clearly defined. Give it a try and let me know.
>>>>>>> Later,
>>>>>>>> Hi, sorry for continuing this story, but I really want to
>>>>>>>> solve this and hope my additional info helps to sort out the
>>>>>>>> problems I face.
>>>>>>>> I am using a shapefile with the imgdate column added to it. I
>>>>>>>> use exactly the same index to work with a WCS on the same
>>>>>>>> data, that one works perfectly fine.
>>>>>>>> I have browsed through the mapServer sourcecode to see if I
>>>>>>>> could discover something/ understand the problem better. I'm
>>>>>>>> not familiar with C coding, so forgive my ignorance :-) What
>>>>>>>> I could understand is that my request fails when the time
>>>>>>>> string submitted in the request is compared to the timeextent
>>>>>>>> given in the capabilities document.
>>>>>>>> The exact section of the code is in between line 545 and line
>>>>>>>> 569, apparently the msValidateTimeValue() procedure fails to
>>>>>>>> find the requested date in the extent. I do not get an error
>>>>>>>> when I change my extent to a range like
>>>>>>>> "2005-09-11,2005-09-21/2005-09-21" or
>>>>>>>> "2005-09-11,2005-09-11/2005-09-21", but it will only render
>>>>>>>> the very last image, even when an earlier one is requested.
>>>>>>>> So I guess I face a bug!?
>>>>>>>> Thanks again,
>>>>>>>> Jeroen
>>>>>>>> Begin forwarded message:
>>>>>>>>> From: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>>>>>>>>> Date: 12 October 2005 09:54:26 GMT+02:00
>>>>>>>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>>>>>>> Subject: [UMN_MAPSERVER-USERS] time series problem 2
>>>>>>>>> Reply-To: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>>>>>>>>> Further to my previous message, the exception I get is the
>>>>>>>>> following one:
>>>>>>>>> <ServiceExceptionReport version="1.1.1">
>>>>>>>>> <ServiceException code="InvalidDimensionValue">
>>>>>>>>> msWMSApplyTime: WMS server error. Time value(s) 2005-09-21
>>>>>>>>> given is invalid or outside the time extent defined
>>>>>>>>> (2005-03-11,2005-03-21,2005-04-01,2005-04-11,2005-04-21,2005-05
>>>>>>>>> -01,2 00
>>>>>>>>> 5-05-11,2005-05-21,2005-06-01,2005-06-11,2005-06-21,2005-07-01,
>>>>>>>>> 2005- 07
>>>>>>>>> -11,2005-07-21,2005-08-01,2005-08-11,2005-08-21,2005-09-01,2005
>>>>>>>>> -09-1 1, 2005-09-21), and default time set is invalid
>>>>>>>>> (2005-09-21)
>>>>>>>>> </ServiceException>
>>>>>>>>> </ServiceExceptionReport>
>>>>>>>>> And the URL's I use are:
>>>>>>>>> For Capabilities:
>>>>>>>>> http://193.43.36.137/cgi-bin/spotveg?
>>>>>>>>> version=1.1.1&service=WMS&request=GetCapabilities
>>>>>>>>> For a working map without specifying the time:
>>>>>>>>> version=1.1.1&service=WMS&request=GetMap&srs=EPSG:
>>>>>>>>> 4326&bbox=-180,-90,180,90&format=image/
>>>>>>>>> png&layers=spotndvi&transparent=true&width=400&height=200
>>>>>>>>> For a request with a time, the exception is returned:
>>>>>>>>> png&layers=spotndvi&transparent=true&width=400&height=200&time=
>>>>>>>>> 2005- 09 -21
>>>>>>>>> These URL's can be reached from outside, so you can try this
>>>>>>>>> yourself.
>>>>>>>>> Thanks in advance for any help to a solution,
>>>>>>>>> Jeroen
>>>>>>>>> On 11 Oct 2005, at 19:20, Jeroen Ticheler wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I have a problem with time series for WMS. I have used the
>>>>>>>>>> following WMS attributes in my map file and I get the
>>>>>>>>>> default image the first WMS map request. The moment I start
>>>>>>>>>> requesting maps with the time variable set, I get an
>>>>>>>>>> exception indicating that the time format used is not correct.
>>>>>>>>>> The data is GeoTIFF
>>>>>>>>>> I have an index shapefile with an imgdate column containing
>>>>>>>>>> the dates in the same format
>>>>>>>>>> Anyone an idea, I can't find an example that has a whole
>>>>>>>>>> range of images with a specific time set for each image.
>>>>>>>>>> Map file extract:
>>>>>>>>>> At the map level (although I don't think this is supported/
>>>>>>>>>> needed for GeoTIFF data!?)
>>>>>>>>>> ____________________________
>>>>>>>>>> "wms_timeformat" "YYYY-MM-DD"
>>>>>>>>>> At the layer level
>>>>>>>>>> "wms_style_default_title" "default"
>>>>>>>>>> "wms_format" "image/png"
>>>>>>>>>> "wms_timedefault" "2005-09-11"
>>>>>>>>>> "wms_timeextent"
>>>>>>>>>> "2005-08-21,2005-09-01,2005-09-11" # also tried
>>>>>>>>>> with spaces after each comma
>>>>>>>>>> "wms_timeitem" "imgdate"
>>>>>>>>>> END
>>>>>>>>>> DUMP TRUE
>>>>>>>>>> TILEINDEX 'ndvi_idx'
>>>>>>>>>> TILEITEM "location"
>>>>>>>>>> EXTENT -180.0 -90.0 180.0 90.0
>>>>>>>>>> PROJECTION "init=epsg:4326" END
>>>>>>>>>> Thanks in advance,
>>>>>>>>>> Jeroen
>>>>>>>>>> Jeroen Ticheler
>>>>>>>>>> FAO-UN
>>>>>>>>>> 12.34327°N 12.34327°E
>>>>>>> Assefa Yewondwossen
>>>>>>> Software Analyst
>>>>>>> Email: assefa at dmsolutions.ca
>>>>>>> http://www.dmsolutions.ca/
>>>>>>> Phone: (613) 565-5056 (ext 14)
>>>>>>> Fax: (613) 565-0925
>>>> gvSIG development Team
>>>> www.gvsig.gva.es
>>> Assefa Yewondwossen
>>> Software Analyst
>>> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
