Tileindex problem
    Eros Agosto
    eros.agosto at POLITO.IT
    Mon Oct 17 07:27:55 PDT 2005
Ed, Frederic...
that's it, thanks!!
Using absolute paths it works!
:O)
thanks again...
I didn't know where to search for the problem..
----- Original Message -----
To: "Eros Agosto" <eros.agosto at POLITO.IT>; <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, October 17, 2005 4:10 PM
Subject: RE: [UMN_MAPSERVER-USERS] Tileindex problem
Eros -
You checked the location field, but you didn't tell us what you found
<g>.  As was suggested, this is likely to be a problem in
misunderstanding paths and how relative paths work in MapServer.  If
possible, using absolute paths is a good idea and prevents that sort of
problem.  At least for debugging, try creating your TILEINDEX with
absolute paths in the 'location' field; if that fixes it, you know where
the problem is.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Eros Agosto
Sent: Monday, October 17, 2005 7:01 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Tileindex problem
Hi List,
I have a problem in using tileindex
I mean:
if I display a raster file (tiff+tfw) it shows: OK
DATA "IGN_50000/psc_3124.tif"
TYPE RASTER
if I display a group of rasters (including the previous one) with
tileindex:
Nothing is showed (except the class name in the legend)
TILEINDEX 'IGN_50000/IGN_50000.shp'
TILEITEM 'location'
 TYPE RASTER
I checked the 'location' field in the tileindex file, I checked the
position of raster files, but it seems OK
Any idea?
Thanks a lot
Eros
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, May 20, 2005 12:19 AM
Subject: Re: [UMN_MAPSERVER-USERS] Image Tiling
I use imagemagick and gdal_translate to split and build tiles from large
images. Then I build a tile index with gdaltindex. As long as you tile
index layers MIN/MAX scales are set right you get a pretty big
performance gain. However if you're rendering many of the tiles in the
same image it slows down. I create overviews for large scales and
display those and have the tile index only come on at lower scales.
-e
Behalf Of Greg Taylor
Sent: Thursday, May 19, 2005 1:42 PM
Subject: [UMN_MAPSERVER-USERS] Image Tiling
What kind of programs/scripts do most of you use to tile .tif images?
I'd be interested in playing with this. Do any of you that use tiled
images notice an improvement in performance?
More information about the MapServer-users
