Upgrade Problems - Additional Info
tim
tibben at OCF.BERKELEY.EDU
Mon Oct 17 14:08:13 PDT 2005
Hi Frank,
I appreciate your interest on this, but perhaps taking a closer look at the
Mercator first would be more fruitful. I got a number of replies from the
PROJ4 list that indicate the problem is related to the Mercator
characteristics, i.e.
>Computing distances is a folly on the Normal Aspect
>Mercator. With two endpoints, just compute the inverse of the cartesian
>coordinates back into latitude and longitude and then compute the correct
>distance with a geodesic inverse.
>For a Mercator map of all of California, there is no *right* scale
>bar. The scale at the top will be different from the scale at the
>bottom. This is true of any Mercator map, just actually visible on
>maps of larger areas. So the scale bar Mapserver is generating is
>probably right for *one* part of the map (perhaps the top or bottom?)
>and the scale bar from your paper map is right for *one* part of the
>map (the middle, maybe? or maybe for right where it is?).
>For interactive things, like desktop user interfaces, it is possible
>to quietly cheat. The measuring tool in uDig, for example, projects
>back into geographic coordinates, and does length calculations on the
>spheroid, rather than naively returning the length in the projected
>plane. In this way it is possible to measure distances in meters
>while looking at a map in geographics, or get correct distances from
>a map in mercator.
>To get correct distances, you will need to calculated great-circle distance.
I am almost sure that I can implement one of these solutions through php
mapscript, but it will mean circumventing the usual measuring tools . . .
If you are still interested, I will try to re-create the visible
differences from the command line mapserv.exe as you suggest . . .
thanks again for the interest
tim
Tim Norris
At 02:47 PM 10/17/2005, Frank Warmerdam wrote:
>On 10/17/05, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> > Thanks for the info. I don't think these instances are using WKT/GML as
> > input or output, if that's what you mean. Basic .ovf connection to
> > provide WMS output. Is there anything we can do on our end to help with
> > this issue? The problem is basically:
>Tom / Tim,
>If you can reproduce the problem at the commandline with mapserv.exe
>from FWTools then just bundle up the minimum data required to reproduce
>it along with the commandlne required to invoke it and submit that as a
>mapserver bug, reassigned to me.
>If you can't reproduce it under those circumstances then perhaps we can
>work out a clue as to what is going from that.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
