one-to-many relationship between Mapserver and PostgreSQL
Pagurek,Debbie [NCR]
Debbie.Pagurek at EC.GC.CA
Thu Oct 20 12:19:16 EDT 2005
One way of pulling your one to many relationship from postgresql is to
use the layer template to set it to a URL, such as a php script, that
passes the city value and that php script then does a query to your
postgresql database and presents the results. There have been posts to
the mapserver list about this and I believe that Richard Greenwood has
published a paper that discusses this technique.
The other way to present one to many relationships, and a method that I
have employed recently, is to embed a URLs right into your shapefile so
that when a user queries each city, they see the URL and click on that
to show the one to many results. The url being one that looks like the
one you would have created in the above example.
Please do some searches in the list archive on "querying" and maybe you
will find examples of these methods. Also - check the mapserver
documentation on templates.
Hope this helps.
D. Pagurek
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Carlo Calvino
Sent: Thursday, October 20, 2005 11:53 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] one-to-many relationship between
Hello everybody,
I use Mapserver to publish some .SHP files. Let's take into
consideration a city layer. We use the Query function to see the data
associated with the city feature, for example, the name of the city, the
population etc. This data is stored in the shapefile. This works fine.
Furthermore, I use postgresql as a database. In one database I have a
table called "Monuments". For each city, there are several monuments. So
the relationship between the city and the monument is one-to-many.
Inside MapServer I wish to click on a city, and the result is the
information inside the shapefile, and also the monuments found in the
postgresql database. Of course, there is the same primary key inside the
shapefile table and the postgresql table, that is the name of the city.
But How i connect MapServer with PostgreSQL?
