faint TT fonts
Charlton Purvis
cplist at EARTHLINK.NET
Thu Oct 20 12:49:54 EDT 2005
Thanks, Frank. I tried playing w/ the ANTIALIAS, and if I make it FALSE, I
get no arrows at all. I also upped the freetype to the latest. If you look
at the attached image of the arrows alone, there are even strange black line
artifacts off the coasts. This is a showstopper, and I'm not quite sure how
to forge ahead.
CLASS
TEXT '®'
LABEL
TYPE TRUETYPE
FONT "esri_cartography"
PARTIALS FALSE
POSITION UC
FORCE TRUE
COLOR 0 0 0
OFFSET 2 -9
SIZE 10
ANTIALIAS TRUE
END
STYLE END
EXPRESSION ([v%STEP_TIME%] >= 1.5)
END
Is there any chance that this target box doesn't understand the .ttf as well
as the box where I didn't see any problems?
Thanks for all your help.
Charlton
> -----Original Message-----
> From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of
> Frank Warmerdam
> Sent: Thursday, October 20, 2005 11:20 AM
> To: Charlton Purvis
> Subject: Re: [UMN_MAPSERVER-USERS] faint TT fonts
> On 10/20/05, Charlton Purvis <cplist at earthlink.net> wrote:
> > Hi, GDAL-ers and MS-ers:
> > The fact that I'm cross posting is a symptom of the fact that I don't
> know
> > where to start digging.
> > I have 2 deployments of the same base data that are using the same TT
> font
> > to produce arrows. Please ignore the difference in background color,
> but if
> > you look at the attached images, you'll see that there is a striking
> > difference in the boldness of the font from the first .gif to the 2nd.
> The
> > MS installations are almost identical, but obviously something isn't
> quite
> > right. I could increase the size of the font on the attachment
> > mapserv2_with_arrows to be able to see the vectors, but that isn't what
> I
> > want to do. Where should I start digging? GD, MS?
> > I'm using pretty much the latest and greatest versions of everything.
> But I
> > can list specifics -- just shout it out.
> Charlton,
> I would suggest looking into the possibilty that FreeType font anti-
> aliasing
> might be in effect in one but not the other. It will tend to make
> features
> less bold and blocky.
> The issue is unrelated to GDAL, but is likely somewhere in the parameters
> that MapServer is passing to FreeType which does the font rendering.
> You could also look for differences in the freetype version though I doubt
> that is it.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051020/b83249a9/mapserv2.gif
