the_geom -> PHP?
Arnulf Christl
arnulf.christl at CCGIS.DE
Sun Oct 23 08:34:11 EDT 2005
Peter Kingsbury wrote:
> Hello all,
> I have some data stored in a PostgreSQL table (point data stored in a
> 'geometry' datatype column) which I would like to turn into legible
> coordinate data in PHP. I've been trawling google for a while, but I am
> having difficulty locating useful documentation on this subject. Not
> sure if I should be checking the PHP or the PostgreSQL documents for
> this info, but digging through both has thus far proven unfruitful.
> Any help would be appreciated. :^)
> Best regards,
> - Peter
if you can access PG with PHPO directly & just want to have the geom in
plain text use the PostGIS asewkt(the_geom) function in the query.
SELECT asewkt(the_geom) FROM whatever
It will return a WKT (Well Known Text) string with the coordinate system
and a list of coordinates.
Best,
